Quick EZ Wiring question
Old Dec 26, 2008 | 04:32 PM
Matt300ZXT's Avatar
Matt300ZXT
So I'm splitting up the sections into front lights, engine stuff, rear lights, etc and I'm stumped. I have the rear turns and parking lights and license plate light set aside, but what powers the actual brake lights? Do I use the orange 3rd brake wire and split it myself or am I just skipping over the actual wire set aside to provice signal when the brake pedal is pushed?
Old Dec 26, 2008 | 04:55 PM
jowilker's Avatar
jowilker
Matt, Turn signals and brake share the same bulb filiment, so if they blink the wire and bulb is working.
On the factory master cylinder out on the firewall, there is a pressure switch that has wires coming through it. With the ign. switch on there should be power to one of the wires, when the brake peddle is depressed the circuit is made and power should go to the rear to lite the lamps.
Check that out to see where you need to go next.
John
Old Dec 26, 2008 | 05:00 PM
Matt300ZXT's Avatar
Matt300ZXT
Well actually I'm using the kit on my 280Z instead of my truck for now, but I figuerd since so many people on here have used the EZ kits in their trucks, someone might know
My car has a brake switch behind the pedal. Two wires going in, I assume one is power and one runs to the back which is signal.
Old Dec 26, 2008 | 05:05 PM
jowilker's Avatar
jowilker
You probably will fry the car using that method.
John
Old Dec 26, 2008 | 07:25 PM
52 F3's Avatar
52 F3
Does the 280Z use seperate bulbs for the rear turn and brake lights. A lot of imports do and it changes the wiring to the rear.
If they are seperate you can wire the rear brake lights and third brake light together. They do not have to be isolated like they would in a system with brake and turn using the same bulb.
Old Dec 26, 2008 | 07:27 PM
Matt300ZXT's Avatar
Matt300ZXT
I think the turn signal and brake light bulb are seperate. I'm pretty sure the parking light and brake light share the same bulb. Either way, I guess I'll have to use the 3rd Brake Light wire and split it in two and run the wire to both bulbs. I was mainly just wanting to make sure I had all the wires I needed, as I've already had to go back and cut zip ties and reorganize wires enough on this thing, I was kinda wanting to get it done right the first time
Old Dec 26, 2008 | 07:47 PM
52 F3's Avatar
52 F3
I think you are right on the brake wires.
If the brake and turn were on the same bulbs they would use the same wires and be isolated by the turn sig switch and the third brake wire would have to be seperate.
On yours you should have seperate wires for tail, turn and brake lights.
nw_ia_guy
16
Feb 13, 2014 04:49 PM
SocialDistortionFan
May 14, 2013 08:18 PM
afonda
Feb 22, 2012 09:17 AM
fns906
1983 - 2012 Ranger & B-Series
Jun 19, 2008 12:19 PM
rick
Mar 11, 2000 11:35 PM
