Sponsored by: Real Truck
Diagnostic Chimes
Old Feb 6, 2007 | 10:34 AM
lamouchr's Avatar
lamouchr
Question Diagnostic Chimes
1999 F-350 Super Duty...
After starting vehicle, I get the standard chimes etc... After it's been running for 1 minute or so, I get 5 chimes (1 per second), then stops for about 5 seconds, then chimes again...
There are no lights on the dashm No check engine light. I know it's got to be a diagnostic problem, but no mention in manual about it...
Can someone tell me it means???
Old Feb 6, 2007 | 02:00 PM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE, lamouchr.
If it's 5 chimes, pause, then 5 more chimes... it's related to the air bag system, and there is indeed info in the manual about it.
Here's some info I've posted in the past from the manual:
Originally Posted by ryaneverk2
It's related to the air bag system (AIR BAG SUPPLEMENTAL RESTRAINT SYSTEM aka SRS), not the anti lock break system (ABS). Here's some copied text that you can find in your owners manual:
"Determining if the system is operational
The SRS uses a readiness light in the instrument cluster or a tone to
indicate the condition of the system. Refer to Air bag readiness section
in the Instrument cluster chapter. Routine maintenance of the air bag is
not required.
A difficultywith the system is indicated byone or more of the following:
• The readiness light will either
flash or staylit.
• The readiness light will not
illuminate immediatelyafter
ignition is turned on.
• A series of five beeps will be heard. The tone pattern will repeat
periodicallyuntil the problem and/or light are repaired.
If anyof these things happen, even intermittently, have the SRS serviced
at your dealership or by a qualified technician immediately. Unless
serviced, the system may not function properly in the event of a
collision."
Hope that helps!
Old Feb 21, 2007 | 09:58 PM
tneyman's Avatar
tneyman
i have ,the same problem, it chimes,when i drive down the road
BigBlueCat
1997 - 2003 F150
Mar 4, 2016 01:48 PM
mrlexse
30
Jan 5, 2016 10:11 PM
jay_d
1997 - 2003 F150
Jan 22, 2014 05:07 AM
Adventure Rider
6.7L Power Stroke Diesel
Sep 8, 2012 01:57 PM
maplelakeduckslayer
1997 - 2003 F150
Sep 10, 2007 05:06 PM
