instrument cluster lights
Old Feb 6, 2007 | 12:34 AM
papa's 64's Avatar
papa's 64
Question instrument cluster lights
my 2001 has some lights that are blown in the instrument cluster for the gauges. Question do I have to pull the dash or does the cluster simply pull out after i remove the three screws that are holding it in. i need to know if this is a 30 min job or an all day job.
Old Feb 6, 2007 | 12:41 AM
tractortug's Avatar
tractortug
It should take a couple of hours. I had two bad bulbs in my cluster, you need to remove the radio, center trim and the plastic piece surrounding the guages and then the guages all come out in a group. I don't remember if you have to drop the steering column but it's no big deal if you do. You also need to disconnect the speedometer cable and a wire harness plug and then the bulbs twist and pull right out of the plastic guage housing. My Haynes manual had a pretty good explanation of the procedure, it was fairly easy.
Old Feb 6, 2007 | 03:16 AM
PW01's Avatar
PW01
When you do it, replace ALL of the bulbs so you don't have to go back in. I replaced mine with 194LL (long life) bulbs.
Old Feb 6, 2007 | 08:18 AM
ctboyle03's Avatar
ctboyle03
This might help some. https://www.ford-trucks.com/forums/3...st2232781.html
Old Feb 7, 2007 | 01:32 AM
papa's 64's Avatar
papa's 64
thanks for the input guys i changed the bulbs tonight hardest part was finding the smaller bulbs mine had 37E in it i couldn't find any so i put a 74 in place everything is brite now. and it only took about an hour to do the whole job from taking it apart to putting it all back together. of course it took about 45 min to get the bulbs but i didn't include that in my time. anyway thanks for the help.
Buyerz
Mar 2, 2014 02:35 PM
RIKIL
24
Mar 9, 2013 03:50 PM
rockcrawler_101
Jul 4, 2011 10:31 PM
just another truck
Sep 1, 2010 07:46 AM
plymouthhater
Aerostar
Sep 25, 2005 11:23 AM
