1978 - 1996 Big Bronco
Hydroboost conversion
Old Feb 5, 2007 | 06:58 PM
rksiewert's Avatar
rksiewert
Anyone have a list of parts needed to do a hydroboost conversion on a 95 Bronco? Any diagrams for the routing of lines? Thanks!
Ray
Old Feb 6, 2007 | 08:28 AM
Kemicalburns's Avatar
Kemicalburns
do a search on google for this. there are a few posts on a bronco forum that i can not name here.
Old Feb 6, 2007 | 02:49 PM
cje07's Avatar
cje07
Information you requested...
This should help you out a bit. Older Bronco...same idea! There is 2 parts to this article...
http://www.4x4review.com/tech/hydroboost.asp
Old Feb 6, 2007 | 06:20 PM
ALSAIR's Avatar
ALSAIR
I did the F-350 Booster and Master cylinder upgrade for around $150 bucks on my "87". She has a hair trigger brake now!! Hydro-booster is nice, but if ya run big tires get a cooler for the fluid.
Old Feb 6, 2007 | 06:31 PM
rksiewert's Avatar
rksiewert
Alsair,
Thanks for the reply. A couple of ?s:
Did you use a saginaw pump? How did you run the lines?
I usually tow a 24ft trailer that weighs in at 7000lbs, but use stock size tires. The power steering pump runs thru a small cooler in front.
Thanks
Old Feb 6, 2007 | 06:41 PM
ALSAIR's Avatar
ALSAIR
I did not install a Hydro-Boost. I simply yanked out all the stock Bronco brake parts and installed F-350 brake parts. There is a major diffrence in the brakes. I looked into the Hydro-Boost. My only concern was availability of parts?? Sticking with a factory type set-up gave me a little confidence that when towing my boat out of town, you know ma & pa auto part stores had parts. However that being said the Hydro -Boost is a nice system.
Old Feb 7, 2007 | 06:13 PM
bossind's Avatar
bossind
Best mod I did to my bronco was fitting a hydro boost system for an e450 into my bronco. I later upgraded to a saginaw pump. Do a google search on bossind and you might find were I posted the builds.
Old Feb 8, 2007 | 03:14 PM
Blown349's Avatar
Blown349
Broncograveyard.com has them
ManfredVonRichtofen
36
May 22, 2014 06:34 PM
okie72
Feb 15, 2014 09:35 PM
F-350PSD
27
Jul 16, 2011 02:33 PM
F-350PSD
Jun 20, 2011 09:57 PM
