Steering column swap info??
Old Feb 5, 2007 | 03:56 PM
tawd77's Avatar
tawd77
I have a 92 f150, and the steering column is worn so the steering wheel flops all over the place. I found a 96 f250 that has basically the same column, but has an airbag, and different cruise buttons on the wheel. Can I swap my steering wheel/cruise/horn assembly onto the newer 96 column? I HAVE to have a functional cruise. Thanks for the help!!
Old Feb 5, 2007 | 06:51 PM
velcro7279's Avatar
velcro7279
The column will physically swap over. I put a 93 column in my 95, but I didn't have to worry about the airbag because I have a 95 F 350 and it doesn't have an airbag and neither did the 93. I would imagine you could just transfer the wiring and steering wheel from your column to the 96 column and you would be good. I can't be certain because I had no experience withe the airbag situation.
Steve
Old Feb 6, 2007 | 07:37 AM
lostin90s's Avatar
lostin90s
Other than wiring differences should bolt up . worst case you cut and splice your plugs to new colomn so plug in Good luck
Old Mar 6, 2007 | 05:52 PM
mgraveman's Avatar
mgraveman
I sent you a PM.
fordka
Sep 24, 2021 05:41 PM
treverd
Jan 9, 2017 09:23 PM
terrylamar
Apr 11, 2016 08:30 PM
speedemon1084
Feb 16, 2016 09:30 AM
WilliamKG88
Sep 15, 2015 08:39 PM
