Locking Rear end
Old Feb 5, 2007 | 01:29 PM
dzzavid's Avatar
dzzavid
Talking Locking Rear end
Hey guys, being new to the truck tuning scene i have a quick one for you. I have an early 99 PSD 250. I was wondering if any one out there makes a rear end that is locking (both wheels spin even if taking turns). Right now if i pull out of my street only one tire spins and tere fore tread is wearing down on that one side. So id rather it be like my mustand and whip teh rear end out a little bit.
any suggestions or name brands to check out?
Thanks
-dave
Old Feb 5, 2007 | 02:22 PM
Offroader6's Avatar
Offroader6
Get you a Detroit Locker. Or if you really wanna throw down some $$$, get an ARB Air Locker. I've got 2 pairs of Detroits, and I wouldn't trade them for the world.
Old Feb 5, 2007 | 02:26 PM
ponch37300's Avatar
ponch37300
Do you have a limited slip rear axle now? It may just need the fluid changed and additive put in? I know it's not the same as a true locker but when i floor mine going around a corner it will kick the rear end out and all i have is factory limited slip 3.73 rear end.
Old Feb 5, 2007 | 07:04 PM
rebelchevy02's Avatar
rebelchevy02
My limited slip has 136k on it, and its tired and wore out. When jacked up, i can move the wheels while its in park, which is not good when you have a limited slip
Old Feb 5, 2007 | 07:19 PM
ssnh's Avatar
ssnh
gmc/chevrolet does
http://www.chevrolet.com/pop/silvera...ng_diff_en.jsp
Old Feb 5, 2007 | 07:24 PM
rebelchevy02
[QUOTE=ssnh]gmc/chevrolet does
http://www.chevrolet.com/pop/silverado/2007/locking_diff_en.jsp[/QUOTE]
That is a locking differential. Not a limited slip. There is a difference. Limited slips generally use clutches, but sometimes gears, to allow them to slip, but generally keeps them together. Clutches wear out and do what mine do, let you spin the tire by hand. A limited slip in good shape, you cannot turn the wheels by hand while the transmixer is in park. Now a locking differential is different. They require torque to be applied on the input (pinion) and wheel slip to then engage, and lock the two wheels together. Generally they stay locked untill you release torque from the input or go passed a governed speed, which they automatically unlock.
Old Feb 5, 2007 | 07:28 PM
ssnh's Avatar
ssnh
Originally Posted by dzzavid
Locking Rear end
<cut>
<cut>
Old Feb 5, 2007 | 07:58 PM
yellow401's Avatar
yellow401
Can't go wrong with the Detroit. I run one with my 35's and like was said, would'nt trade it for the world. Damn near bulletproof!!!!
Old Feb 5, 2007 | 08:06 PM
hosemandc's Avatar
hosemandc
Detroits are great but I have had to learn to drive all over again when I had one in my off roader. Winter roads are crazy when you lock up the rear. If you lock it up you should bare no expence and get a good one or you might end up dragging a tire when you turn like with a spool. Some of the cheaper ones are noisy and clunk real bad when you turn. They seem to wear out tires quick too if you are heavy on the throttle through corners. A good Auburn Gear limited might be better for street applications.
Old Feb 6, 2007 | 06:59 AM
dzzavid's Avatar
dzzavid
thanks guys
Old Feb 6, 2007 | 09:20 AM
99 7.3 towrig's Avatar
99 7.3 towrig
Id stay away from Auburn, I had one i my mustang, was fine with street tires, but 2000 miles with drag radials an it was just like having an open rear.. the clutches were shot, an they are not rebuildable, so 22k on a $400 some rear was a waist. iv hear alot of bad things about them from other mustang owners. If you want a true locker go detroit all the way, I hear great things about them in the off road world. my limited slip is dead too, you can spin the tires when in park on the lift, id rather just spend alil $$ an rebuild it then have to go through setting the gears up agian with a different diff.
Old Feb 6, 2007 | 08:38 PM
Zephyr's Avatar
Zephyr
I have also heard some negatives about Auburns, BUT I have an Auburn Pro in my '93 mustang (novi 2k 347 5speed 4.10s) with over 37k on the diff & its rock solid. I have Detroit locker (rear) & Trutrack (front) in my '84 Toyota trail rig & they work great, though the rear does chatter when you make tight turns on pavement.
Old Feb 6, 2007 | 09:28 PM
rusty350250's Avatar
rusty350250
go detroit locker. a little gas and it will lock up on turns
Nick2005f250
Jan 19, 2014 07:06 PM
Baatzy
Oct 9, 2013 02:28 PM
wildstang
Apr 27, 2010 12:22 PM
medicpg
May 17, 2003 05:33 PM
Deerchuck
Oct 29, 2002 10:28 PM
