2005 conversion
Old Apr 24, 2007 | 10:12 AM
  #31
Layson's Avatar
Layson
Originally Posted by tidbit
quick question...
i want to go 05 harley (i have an 04).. My truck got damaged and the stock 04 header panel got damaged..
can i order an 05? or should i stick with a 04 panel and modify it.. I noticed someone saying that you cannot use the 05 header with an 04 bumber.. that true? and solid answers would great.. Just want to know what parts are compatible.. thanks
I think I would stick with the 04 header panel if you are going to use the 04 bumper. Then you can mod it for the headlights.
good luck,
Steven
Old Apr 24, 2007 | 10:13 AM
  #32
Layson's Avatar
Layson
also.. anyone know where i might be able to snag a set of harley headlights cheap?.. thanks!
I don't know about the cheap part. But www.powerstrokeshop.com and www.1stfordparts.com have pretty good prices. You could start there and send them some emails for quotes?
good luck,
Steven
Old Apr 24, 2007 | 10:21 AM
  #33
tidbit's Avatar
tidbit
thanks steven
Old Apr 24, 2007 | 11:50 PM
  #34
RACERX7775's Avatar
RACERX7775
if you want to use the 04 bmper, you must use the 04 header. its not that the header will not work, its just that the 04 grill will not clip in at the bottom. what are you doing about a gril? are you getting a new grill? if the truck is damaged, this would be the best time to do everything.
Old May 11, 2007 | 02:23 PM
  #35
tidbit's Avatar
tidbit
i'm just not sure if i want to replace the bumper... i cant use the 04 bumper with an 05 grille right?... i am a bit torn as to what i want to replace..
Even though i've been paid for the repairs i cant justify replacing a bumper with a small tiny scratch..
Old May 11, 2007 | 04:39 PM
  #36
Layson's Avatar
Layson
Yes you can. Just trim off the bottom of the 05 grille. Lots of guys do that. Tape it off and trim away with a dremel tool. Then zip tie in the bottom of the grille. The main mounts are at the top and they line up fine. The bottom mounts will not work since the header panel is just a tad bit different then the older style.
If you want to upgrade the whole front end later just sell the grille. You will have no problem selling it.
good luck,
Steven
