2005 conversion
Old Mar 1, 2007 | 07:36 AM
VaSheriff's Avatar
VaSheriff
It bolts right in. 4 screws at top, and the pop in brackets at the bottom. Just like the grille you will be taking off.
I received mine in 3 days.
It is a 2005 Ford Original Equipment F250/F350/Excursion grille which has been modified at the bottom to fit around the pre-2005 bumper. The seller does an excellent job on altering them to fit.
It's the best way to achieve the 2005 look without having to change out the entire front end.
Old Mar 1, 2007 | 07:37 AM
Rays98govols's Avatar
Rays98govols
It couldn't be easier. You remove the four phillips screws on top of the grill. You gently pull on the bottom of the grill to remove the spring clips. Make sure no clips are left behind. You reverse the above to install. 10 - 15 minutes tops.
Ray
Old Mar 1, 2007 | 11:57 AM
VaSheriff's Avatar
VaSheriff
Ray
10 to 15 minutes? Did you take a break and drink a beer?
Old Mar 1, 2007 | 09:20 PM
mike330's Avatar
mike330
I checked ebay and there is two guys listing grills . One has shipping for $35 and the other is $22. Which one did you guys get?
Old Mar 2, 2007 | 12:26 AM
Layson's Avatar
Layson
You could even do a cheaper route.... or use a different grille. You could also go with a chrome package grille...kinda like a billet only plastic. Or just get the XLT grille. You can get a brand new one for like 170 bucks shipped or the chrome package for 200 shipped...I think the harley one is 230 shipped...somewhere around there. www.powerstrokeshop.com Then with the extra money you save buy yourself a dremel tool and some masking tape. then trim about 1.5 inches off the bottom. I went ahead and did the full conversion though from www.powerstrokeshop.com. There are alot of possibilities.... you could just do the headlights if you like those???
good luck,
Steven
Old Mar 2, 2007 | 11:08 AM
VaSheriff's Avatar
VaSheriff
This guy.....
http://cgi.ebay.com/ebaymotors/2005-...94228765QQrdZ1
Old Mar 3, 2007 | 08:41 AM
mike330's Avatar
mike330
Thanks , it looks great, I wanted to make sure i got the right one .
Old Mar 4, 2007 | 08:15 PM
caddys83's Avatar
caddys83
heres mine
Old Mar 5, 2007 | 07:14 PM
mike330's Avatar
mike330
I see you changed the bumper too.
Old Apr 18, 2007 | 01:07 PM
billygoat's Avatar
billygoat
So let me confirm....if you want to change the look of your X from a pre '05 (I have an 02) to look like an 05, you need to change the front grille, bumper and headlights? Do all these pieces bolt onto the existing brackets?
TIA
Old Apr 18, 2007 | 02:08 PM
Layson's Avatar
Layson
Yes you can. You don't have to have the header panel. You will have to modify (cut) it so the headlights can fit. Here is how you do that...
http://www.puredieselpower.com/Tech/...Conversion.pdf
Then for the grille. it will mount directly to the top of the header panel with no modifications. But the bottom support...which is pretty much useless can be ziptied back to the header panel using the brackets on the back of the newer grille. Then the bumper will just bolt on with no changes. You will have to pick up the new pig tails for the headlights. Here is a good site that shows how to do the conversion with the header panel. It shows all the part numbers.
http://www.kingkustomstemecula.com/wst_page14.php
You can get all the parts for a great price from www.powerstrokeshop.com I went ahead and purchased the full conversion kit they have that includes everything. It just made it alot easier. Plus if you want to get a harley style grille, or chrome package grille, or the harley smoked headlights...they can put together a kit for you. You can get all this from Ebay but you have to watch out for shipping...that is where they will get you.
good luck,
Steven
Old Apr 18, 2007 | 02:22 PM
Timido's Avatar
Timido
Here is a Friends 2000 Looks killer I like that front end. If anyone is interested in a nice truck http://bbs.hardcore50.com/vbulletin/...ad.php?t=38222
Old Apr 18, 2007 | 11:40 PM
  #28
RACERX7775's Avatar
RACERX7775
billygoat, check my gallery for some pics of my 06 sd conversion. just gives you some different ideas with lights and stuff.
Old Apr 24, 2007 | 01:02 AM
  #29
tidbit's Avatar
tidbit
quick question...
i want to go 05 harley (i have an 04).. My truck got damaged and the stock 04 header panel got damaged..
can i order an 05? or should i stick with a 04 panel and modify it.. I noticed someone saying that you cannot use the 05 header with an 04 bumber.. that true? and solid answers would great.. Just want to know what parts are compatible.. thanks
Old Apr 24, 2007 | 01:08 AM
  #30
tidbit's Avatar
tidbit
also.. anyone know where i might be able to snag a set of harley headlights cheap?.. thanks!
