Bronco II Ford Bronco II
Rear brake lines
Old Feb 4, 2007 | 08:55 PM
lugnut05's Avatar
lugnut05
Rear brake lines
Are the rear lines from the block on the Banjo to each wheel cylinder
inverted or bubble flare, or a standard flare ?
Old Feb 4, 2007 | 08:56 PM
lugnut05's Avatar
lugnut05
Forgot to ask....
Although I am capable of making new rear lines , does anyone offer them , prefabed in stainless tubing ?
Old Feb 4, 2007 | 09:46 PM
kernel-panic's Avatar
kernel-panic
I think the only place you'll get pre-fabbed lines are from a dealership, unless anyone else carries them. I just know the fitting on the wheel cylinder is larger than the one on the block, and they are flared.... I'm guessing bubble flared, if that means you bubble the end and push the end in when you flare it? Not sure... I replaced one of mine the hard way and ended up having to cut the pre-made line short and get a fitting to adapt the too-small end to the size of the wheel cylinder fitting opening.
Old Feb 5, 2007 | 01:58 PM
rebocardo's Avatar
rebocardo
I believe the proper term is "double flare". Yes, they are "double flare".
You can buy prefab stainless steel lines from places such as www.inlinetube.com
I had called a few places when doing my 86 BII, but, when I found a complete set was about $300 and I paid $600 for the truck I went steel and bent my own.
Old Feb 5, 2007 | 02:30 PM
OSin86's Avatar
OSin86
They should be a standard invert flare (most common). Less then a $20 job if you do it yourself.
Old Feb 5, 2007 | 03:24 PM
lugnut05's Avatar
lugnut05
I believe a company called "fine lines" makes fuel and brake lines for vintage vehicles.
Not sure they are offered for the Bronco II.
fishwhisper
Aftermarket Products
Jun 30, 2013 12:42 PM
F-WhiteThunder
Feb 13, 2012 08:28 PM
pete17c
Apr 3, 2010 02:38 AM
X-Hibition
Nov 23, 2009 06:47 PM
