Realigning a Fender
Old Feb 4, 2007 | 08:58 AM
Nightrain's Avatar
Nightrain
Realigning a Fender
Somehow or another, the passenger-side fender on my 1992 F-150 Super Cab got out of alignment, and I can't open the door without it popping and causing damage to the fender and door itself.
There are four bolts that tie the fender to the radiator support, two bolts just down from the cowl panel, and one just forward of the door/fender seam. I'm sure there are more, I just don't know where at the moment.
I guess my main question is... Once I find all of the bolts and loosen them, do I just wiggle the fender to the position that it needs to be and bolt it back down? This is something that I've never done before.
Thanks, ya'll!
Nightrain
Old Feb 4, 2007 | 11:07 AM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Yep, once you get them all loose, you should be able to move it generally about 1/8 - 1/4" which should give you more than enough flexibility to get it out of the way of the door, then just tighten everything back up and you shouldn't have anymore problems.
Old Feb 4, 2007 | 12:23 PM
Nightrain's Avatar
Nightrain
Thanks, Indy. I appreciate your input!
Nightrain
Old Feb 4, 2007 | 12:29 PM
Indy_Gearhead71
Sure thing,, always glad to help out when I can, but it's odd that it just moved around without the help of an accident or something. Might wanna ask the ole lady what she was doing in the truck. ROFL
Old Feb 4, 2007 | 12:42 PM
Nightrain's Avatar
Nightrain
LMAO @ Indy...
I tell you what I think happened... The other day, I was backing my 24' gooseneck with the truck in the driveway. To accomplish the sharp angle that I had to back the trailer in, I had to go diagonally across a drain ditch in the yard. Right after that, I noticed the door started popping and hanging.
I'm going to have to weld some reinforcements in this 'ol frame... It's gonna have to get stiffer than that!
Nightrain
Old Feb 4, 2007 | 01:43 PM
Indy_Gearhead71
Just wrap the sucker with some 11 guage and never worry about it again,, who cares if it weighs another 400# when you're done.
Old Feb 4, 2007 | 02:17 PM
Nightrain's Avatar
Nightrain
That's exactly what I'm talking about.
What I was thinking, in future terms of course, is weld a brace straight across the frame beams, right under and back a bit from the radiator support.
Then, with the bed off, I plan on welding 4-6 braces from frame rail to frame rail to really stiffen up the back.
Nightrain
Old Feb 4, 2007 | 02:30 PM
Indy_Gearhead71
Stiff won't begin to describe it,, hope you have some suspension to go with it or it's gonna be one rough ride.
Old Feb 4, 2007 | 02:39 PM
Nightrain's Avatar
Nightrain
All of that's in the making!
lol.
Nightrain
Old Feb 4, 2007 | 03:35 PM
Indy_Gearhead71
Good man, I like the way you think. Quoting Sam Kinison in Back to School
" I like you,, yeahhh, I like you,, I'm gonna keep my eye on you.. I like the way you think "
Old Feb 5, 2007 | 12:44 AM
Nightrain's Avatar
Nightrain
LMAO again...
10-fer there, Indy.
Nightrain
