Rusted Floor Pans
Old Jan 26, 2007 | 01:56 AM
daveengelson's Avatar
daveengelson
Rusted Floor Pans
May need to replace at least 1/4 to 1/2 of driver side floor pan. Wonder if it would be best to replace using 2 panels, or the entire drivers side with 1 panel. Not that knowledgeable, have some oxy-acyl experience, intend to purchase mig welder. The pans are marginal and may be repairable, thought would check with and see if anyone had any success repairing floor pans.
dave
Old Jan 26, 2007 | 07:03 AM
cujo8's Avatar
cujo8
I had to repair an 8" hole in my PS floor pan, so I just cut out the rusted area and mig welded in a patch. The rust area on mine was not big enough for me to go out and buy a patch panel, so I just fabbed one up out some sheet metal I had in the garage. Generally if you have a lot of rust in your floor pan you should buy a replacement panel of the appropriate size, but only use as much of the patch panel as needed to repair the rusted section. I prefer to use a MIG welder to do these kinds of repairs. Good luck.
Old Feb 3, 2007 | 04:39 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
The only real question comes down to whether or not you plan on keeping the truck or selling it down the road and who might be the buyer. I don't like doing patch panels personally since floorpans really aren't all the expensive and not too much trouble installing them, plus the finish product just looks better in the long run.
Old Feb 4, 2007 | 11:36 AM
daveengelson
Interesting, no email notifying anyone responded to my post. Appreciate the info. Going to be keeping the truck, and as a 'do it myselfer' intend doing the body, and paint work. Truck is marginally salvageable, sat for sometime and there is alot of surface rust, but 2 or 3 areas where rust is serious and will need to be replace. Truck was originally one step removed from having a cutting torch taken to it, having no experience w/ MIG, thought I would start with the floor pan and if they come out alright, then procede to rescue the truck. Believe the passenger side can be saved w/ patch panel, thin metal mesh blends in w/ the topcoat, no holes but very thin in area's. Driver's side is another issue, will need to be replaced. Have an oxy-acyl setup that am still learning to use, not familiar with MIG welding, looking to purchase refurbished 220V setup if the old home wiring can handle w/out tripping a breaker. Again, appreciate the information.
dave
Old Feb 4, 2007 | 11:51 AM
Indy_Gearhead71
Anytime man,, and working with a mig really isn't all that bad, get a decent book and practice on some old scrap pieces first to get your temp and wire feed settings comfortable. Since you're planning on keeping it, I'd still go ahead and put in a new floorpan section, it'll be less headaches down the road.
Old Feb 4, 2007 | 11:53 AM
cujo8's Avatar
cujo8
I use a 110V MIG and it works just fine and 110V makes the welder a lot more versatile in that you can move the welder where it needs to be using std 110V power.
Old Feb 4, 2007 | 12:03 PM
Indy_Gearhead71
I totally agree cujo, and for what he's going to be using it for, a 110 version will work just fine, you can even tackle a bit of frame welding with a 110, it's just not as fast or as pretty as a 220 will get you. If the main goal is going to be body sheetmetal and such, I wouldn't worry about the 220 version, especially if you have power problems.
Old Feb 5, 2007 | 12:19 PM
daveengelson
Appreciate the info, was concerned whether 115V setup would meet my needs, don't seen any heavy structural welding being done. The 220V outlet is relatively close but still would require moving vehicle to do any welding. Did want to make body dolly of some sort and the oxy-acyl unit can be used for that purpose. Thx again.
dave
pcurtice
Jun 26, 2015 11:29 PM
mgeorge0090
Paint & Bodywork
Jun 7, 2015 01:16 AM
Joel Cassell
47
Aug 10, 2014 06:10 PM
73 Crew
Dec 18, 2012 10:48 AM
gultar
Paint & Bodywork
Sep 12, 2002 01:36 AM
