Crank main bearings
why do you think it's gone out on you??
thats how you test it....measure how far the crank moves in and out, I use a ball joint checker......dial indecator on a flexable cable thinky......
The bearing will only roll around the crank one way, look at the bearing in the main cap and you'll see what I mean. I used a small punch with a plastic hammer, tapped it around the crank until it was out enough to get by hand.
good luck.............
The thrust bearing is almost always the hardest to install. (It offers more friction because of the cheeks on each side of the bearing shell.) Do the same as with the others...push in by hand, roll and then tap in place. If you have never done this before, practice rolling a used bearing insert in place. Once you do it, you'll see that there is nothing to it.
Be very careful not to damage the bearing/shaft surfaces while installing any one of these inserts. Reinstall each insert just the way it appeared before you removed it. You will notice that the bearing insert is not flush with the block and/or cap. Do not try to file or otherwise remove this material. The bearing is designed to have "crush" so that it will fit tightly into the bearing bore.
(You don't have to, but just for grins, you might want to check the old inserts for crush before removing them. You might be able to feel the edge of the bearing insert sticking slightly above the machined flat on the block and/or cap. Another way to visualize bearing crush is to imagine putting your feet into a pair of shoes that is one size too small. Your feet are jammed in there and are guaranteed not to move.)
Crush keeps the bearing inserts in place and in so doing, aides in the heat transfer to the bearing housing. This is essential. This is why the backside of the insert should be perfectly clean and dry (free from oil). Over time, any oil on the backside of the insert can dry-out and form a residue that actually reduces the heat transfer from the bearing shell. Not a big deal. Just a fine point.
One last comment is needed re: installing the thrust bearing. Crank shaft end play should be checked. There are good reasons for doing this. If the measured end play is greater than the rod big-end clearances, you can run the risk of trying to squeeze the big ends together as the motor runs (the crank will actually slide forward and squeeze the big ends so that they can actually overheat...and turn blue on the machined surfaces). This is definitely not good. For what it's worth, any engine that you ever tear down, crank end play is definitely something to take note of as you are taking it apart. If you find excessive end play, make sure and check the rod cheeks (machine surfaces on the sides of the big ends) for discoloration and side clearance while still sitting on the journal. Keep in mind, that by increasing the side clearance of the connecting rods (big ends), your oil pressure will be lower than an identical engine with proper side clearances AND the oil pressure will continue to drop off the faster you wind the motor. If you were going to rebuild an engine (for a daily driver) and want to keep the costs down by re-using the crank and found that the endplay with new bearings was excessive, get another crank that gives you good numbers. Do not reuse the original crank.
Sorry about all this crap. I kinda got sidetracked.
One more thing about the thrust bearing installation. Once you have installed both halves of the bearing and have lightly reattached the bearing cap, you will want to seat the thrust bearing by using a large screw driver/pry bar before you complete the torquing of the cap. (I know, you are getting tired of reading....and I'm getting tired of typing.)
A couple of additional hints:
1. When rolling an insert into place, make sure and clean any debris that might be scrapped off the bearing bore as the insert is being rolled into place. If present, the crud will end up at the parting of the bearing insert (the leading edge of the insert...the first part of the insert that becomes visible as you are rolling it into place). Remove the crud and reassemble the bearing.
2. When reassembling a bearing cap to the block, make sure it's facing the same way as it was before your removed it. You want to replace the bearing cap facing the same way as it was originally installed !! Mark it somehow (scratches, punch marks etc.) so that you put it back together correctly.
3. When reassembling the bearing cap to the block, lightly tighten the cap bolts and then "lightly" tap the center of the bearing cap with a brass hammer. A LIGHT TAP will help settle everything into place. Then finish tightening. This step is not a big deal. It's just a fine point.
4. And lastly (thankfully), rotate the crank after each new bearing has been oiled and installed. Is it too difficult to turn ? Something is wrong. Take the cap off and inspect your work. If you are going to check clearances using plastiguage or a product like this, you will probably want to check the clearance with no oil on the shaft or bearing shell. (You are not going to turn the crank...you are just installing the cap, torquing to spec, disassembling and checking the width of the squashed peice against the side of the package that it came in. Then, remember to oil the shaft and bearing cap, install and torque to spec and rotate to check the finished assembly.
Good Luck !
I have done rod bearings before, but not these, so thats a plus.
So are you saying that once I put in the new bearings and check endplay, if its too much then I need a new crank? And about the oil on the bearing, am i understanding right to not put on oil? I think I am misunderstanding, but I'm not sure. Thanks for the pin tip, come monday I hope to put it to good use
"[/QUOTE]If the endplay is excessive with a new thrust bearing, then your crank must be exchanged for another. (Your original crank will have to have the thrust faces adjacent to the thrust bearing journal welded and ground back to specs along with the proper journal radius reground as well.)
If you are going to use plastiguage to clearance a bearing, then it is best done dry. (You want the plastic strip to stick so it is easier to measure its width. If you oil the shaft and then put the strip in place, it will slide all over and react with the oil....a mess.) Once you are done checking, then oil the bearing cap insert and the shaft...rotate the shaft to spread the oil around a little....and then reinstall the cap.
I think that some folks frown upon the use of white lithium grease when assembling a bottom end, but I used to use it all of the time. The mains always have grooves in the inserts. If I were rolling a main into place, I would pack the grooves with grease and then insert them...instant lubrication no matter how long the engine sat before it was started. The oil pressure would quickly replace the grease with oil. It wouldn't harm anything. It always seemed to work for me. So long as there is some lubricant in place for the startup, that's all that really matters.
