rear washer
Old Feb 2, 2007 | 03:55 PM
greenterror's Avatar
greenterror
Question rear washer
rear window washer not working.do you put fluid in diffrent spot? or is it the motor
Old Feb 2, 2007 | 04:29 PM
CobraXP's Avatar
CobraXP
What year?
Most of the rears have their own tank in the rear left compartment. The fill spot is on the rear pillar. Open your hatch and look on your left pillar somewhere around the cylinder holding the hatch up. THere will be a rubber flap there. You pull it out and fill in that spot.
Old Feb 2, 2007 | 04:36 PM
jerrym's Avatar
jerrym
Washer fluid rear window
On the early models before 1997 it is stored in a reservoir in the left quarter panel. You remove the access cover from the left side of luggage compartment. On 1997 and later the fluid is stored in the main washer compartment in the engine compartment.
Old Feb 2, 2007 | 05:35 PM
Steina's Avatar
Steina
CO River Rat
Your '02 has the same reservoir (right front in the engine compartment) for front & rear washers. Are the front washers working?
Steve
Old Feb 2, 2007 | 08:05 PM
greenterror
02 rear fluid
[QUOTE=Steina]Your '02 has the same reservoir (right front in the engine compartment) for front & rear washers. Are the front washers working?
Steve[/QUOTf E]
Old Feb 3, 2007 | 10:06 AM
pbjohns's Avatar
pbjohns
On my 02 explorer, the washer is supplyed by the container in the engine conpartment, Ford used a T connection type splice for both, front and back. I had it come undone, it is located, under and to the back of the water bottle. If the front still spray, and the back don't, it is a good chance that is your problem.
lionsteve
Jan 29, 2014 11:20 AM
vczar1
Mar 24, 2013 12:45 AM
Big Sky
Mar 17, 2010 07:52 PM
