Usually they just come loose at the connectors. But the inside runs from the one at the passenger kick panel, it runs inside the vehicle wiring trough, down the passenger side behind the side panel and then up to behind the rear dome light where the next connector is. Most common issue is the nozzle will freeze and cause the line to pop off at one of those connections.
