1978 - 1996 Big Bronco
Fuel Pump Question
Old Dec 31, 2002 | 09:44 AM
BigFootnHawse's Avatar
BigFootnHawse
Post Fuel Pump Question
I have a '96 Bronco that has been sitting for a while and currently won't fire up. It turns over, fires up briefly when using ether, then dies again. I have heard the pump relay clicking, but can't hear the pump itself. When pressing the schrader valve on the fuel rail, a little fuel very slowly bleeds out. I put a pressure tester on the valve and got a 0 reading.
I am assuming the pump of bad, as I have changed out the fuel filter, and turned the ignition on with the line coming from the tank over a bucket (not a drop of fuel came out). And yes, the inertia switch is in the correct position.
If any of you think the pump is bad, can I add an inline pump along the frame rail and wire it in as opposed to dropping the tank to replace the factory pump? Also, can I simply wire the new inline pump using the same wires for the factory pump?
Any help would be appreciated since I am about to embark on a straight axle conversion.
--LR.
'96 Black Bronco, 6" Superlift, 4.11 gears, Detroit C-locker rear, Tru-Trac front, 36" Swampers
Old Dec 31, 2002 | 05:10 PM
steve83's Avatar
steve83
Fuel Pump Question
You can't use an inline pump - you have to fix the OE one. The fuel system is dependent on that pump making pressure for fuel to be able to return to the tank, and a Haynes manual ($12) explains why in detail.
Dropping the tank isn't as bad as you've probably heard, especially if you siphon it nearly dry before you start. Another BIG help is to keep the 8 bolts wet with Liquid Wrench for a few days before you start. You'll need the coupling tools, but you can get a full set of Lisle or CarQuest ones for less than $10 and you'll need them for other fittings on the truck. Look at pictures #44-47 here:
http://www.webphotos.com/list_photos.asp?mi=3&smi=2&a=66912
When you get it out like they show, you can try to power it up and see if it runs. If it does, then you might be able to find the blockage & fix it - the plastic housing is easy to remove from the pump motor.
Old Dec 31, 2002 | 05:14 PM
steve83's Avatar
steve83
Fuel Pump Question
Jymmm
21
Apr 3, 2019 12:52 AM
Atphelan
Dec 20, 2015 06:14 PM
bobcf
Aug 17, 2015 08:56 PM
75_92_95
13
Jul 22, 2015 08:47 AM
dustermaniac
Oct 2, 2005 05:57 PM
