Offroad & 4x4
Winch From Sams
Old Feb 2, 2007 | 12:32 PM
bc56845's Avatar
bc56845
Winch From Sams
Just thought I'd pass this on-I heard that Sams Club sold a 7500lb Ramsey winch for 300 bucks, so I looked on thier website and there it was. Most of the stores in my area are sold out of them, As soon as I find a store that has one in stock I'm gonna go check it out and see if it seems beefy enough. 7500lbs isn't as big a winch as I'd like, but you can't beat it for 300bucks- if its a real Ramsey. Anybody bought one of these?
Old Feb 2, 2007 | 01:35 PM
fishmanndotcom's Avatar
fishmanndotcom
i had 3 and broke all three within 2 months
i have had my warn 8274 i bought used for $75, rebuilt it for about $50 and has served me well for the past 3 years! it'll drag my 7500lb CC/LB PSD like its nothing!
Old Feb 2, 2007 | 02:39 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
7500lb is def way too small, i guess it'd be good for a stock jeep or toyota or maybee a big 4 wheeler
Old Feb 2, 2007 | 03:40 PM
fishmanndotcom
i've run the 8274 on my bronco, PSD, and white truck and it NEVER gave me a problem! its an 8000lb'er. my PSD weighs a lil over 8000 loaded and it still pulls single line with all 4 tires locked down
-cutts-
Old Feb 2, 2007 | 03:55 PM
quadzjr's Avatar
quadzjr
im jus curious what do you use you winch for?, rock crawlin?
i know if you totally sink 40's or 44's under mud on a full size truck, a 8000lb winch isn't going to help at all.
or maybe im just used to some nastier mud
Old Feb 2, 2007 | 04:02 PM
fishmanndotcom
i use my winch for everything! i have used it on the rocks in the bronco trying to climb a vertical rock wall and had the winch help keep my nose down. used the winch on the powerstroke a once with a loaded trailer and once to literally pull down a tree. but i mostly used the 8274 to drag my white truck out of the mud. last time i used it on theat truck i was at a buddies house and found some dozer tracks. i got my 1 tons high centered and for the rest of mud stretch (about 50 yards) i had to use it to drag the truck out. tires didnt touch hard ground for almost the entire 50 yards. also had a bad stuck in my back yard in the swamp, buried 3 of the 4 tires (one was on a root) and had to winch out. that time i used a ****** block b/c i didnt wanna snap my brand new AmSteel blue so i was trying to be cautious, but after using the stuff for so long i know it would have handled it
-cutts-
Old Feb 2, 2007 | 04:32 PM
quadzjr's Avatar
quadzjr
i dont know then, but i know for fact that when you sink 40's in the mud down here, the suction on the tires is so great that using a 10000lb is sketchy, ive seen a s-10 on cut 44 boggers get stuck, and a 12000lb winch burnt up trying to pull it, i guess its just the mud, i dont know
Old Feb 2, 2007 | 07:03 PM
fishmanndotcom
i have to agree with you actually! florida sandy mud seems to have a bit of a suction to it, whereas ou GA clay just gums up the tread and its real hard to clean'em!
i was mainly saying that a good 8000lb winch will work just fine for MOST situations, and if you happen to get in one of those florida mud holes grab a ****** block and double your strength!
-cutts-
Old Feb 4, 2007 | 04:08 PM
bc56845's Avatar
bc56845
Were these the ramseys from Sams?
bigred66
Apr 1, 2011 12:52 PM
*2fords*
Offroad & 4x4
May 7, 2010 05:32 PM
monckywrench
Offroad & 4x4
May 12, 2009 07:39 PM
ronross
1983 - 2012 Ranger & B-Series
Aug 29, 2005 06:45 AM
tmehrkam
Feb 29, 2004 06:20 PM
