96 PSD auto
Old Feb 2, 2007 | 10:27 AM
scottie2hottie's Avatar
scottie2hottie
Question 96 PSD auto
does a 96 PSD have a lockup torque converter?
Old Feb 2, 2007 | 10:51 AM
tjbeggs's Avatar
tjbeggs
yes it does
Old Feb 2, 2007 | 11:52 AM
Casey's Avatar
Casey
Most of them do. Most had the E4OD trans, which does have a lockup converter. A small number were built with the C6 trans, which does not have a lockup converter. The easy way to tell is on the end of the shifter. If there is a button with an OD OFF light, it's the E4OD.
Old Feb 2, 2007 | 12:09 PM
tjbeggs's Avatar
tjbeggs
pretty sure no powerstrokes had a C6. the older 6.9 IDI and 7.3 IDI did but not 7.3 powerstroke
Old Feb 2, 2007 | 12:36 PM
scottie2hottie
agreed ford quick makin c6s in 91
Old Feb 2, 2007 | 01:48 PM
Cuda_jim's Avatar
Cuda_jim
Yep no c6's in a PSD but I sometimes wish they did! One of the toughest trannys ever made.
Tim, did you get the hyperlink in your sig figuered out?
Old Feb 2, 2007 | 02:00 PM
Casey's Avatar
Casey
Ford made C6's through the '96 model year. They were available with the diesel, 460, and 351 in F250 and up, plus the E350 and up.
Old Feb 2, 2007 | 02:13 PM
tjbeggs's Avatar
tjbeggs
I had a 95 PSD and it had a E4OD. No C6 there. maybe it was option but not to my knowledge was it offered.
Old Feb 2, 2007 | 02:15 PM
tjbeggs's Avatar
tjbeggs
oh and cuda-jim no I haven't got that crazy thing figured out. I got a PM into Kwikkordead to see if he can give me any insight
Old Feb 2, 2007 | 02:16 PM
Casey's Avatar
Casey
Most were E4ODs, but there was a small number each year through '96 that were C6.
Old Feb 2, 2007 | 04:19 PM
scottie2hottie
Look any where at C6 info for rebuilds etc. nothing available after 91. only autos available that may resemble C6 were AODE, still not a C6. Every truck offered with a PSD was also given a OD tranny- be it manual or automatic. They all had overdrive. If you can find some documented proof I may start to believe you, but I'm 99.99999% sure you're wrong about the C6
Old Feb 2, 2007 | 04:20 PM
scottie2hottie
ok jes called my local ford dealership parts dept. They didn't put a c6 in a 94 powerstroke because they couldn't get service parts for one. If that ain't proof i don't know what is.
Old Feb 2, 2007 | 06:40 PM
Cuda_jim's Avatar
Cuda_jim
I found the following at TCI (Torque Converter manufacurer
CLICK HERE About half way down the page
They made the c6 from 1988-94 for the 7.3L Diesel but not the powerstroke, IDI only.
Old Feb 2, 2007 | 06:53 PM
scottie2hottie
LOL looks like we both gotta admit defeat.
