Cold Temp squealing alternator
Old Feb 2, 2007 | 08:53 AM
billyblaze's Avatar
billyblaze
Unhappy Cold Temp squealing alternator
In temps colder than 10 degrees ambient air my alternator squeals as if there is some sort of electrical interference. The dealer checked it and said this is a known problem between 1900 - 2400 rpms. It is the alternator that Ford uses and it happens in trucks, cars, all vehicles in similar weather. Has anyone had this experience and if so have you had succes with swapping the alternator. it is incredibly annoying. Thank you
Old Feb 2, 2007 | 10:36 AM
Franklin2's Avatar
Franklin2
Is it a whining noise like it normally makes only louder, or is it a mechanical squeal? I am assuming when it's that cold, you have the defrost on high, and possibly a window defroster or other elec loads on it. If you turn all these off does it quit making the noise?
Old Feb 2, 2007 | 11:14 AM
billyblaze's Avatar
billyblaze
Alternator squeal
it is an interference squeal, like holding a microphone too close to a speaker. Not the same squeal as if the alternator is going bad. At one point I thought it could be the cell phone, disproved that. Thought it could be the radio, disproved that. Thought it could be the heated seats, disproved that. Typically the defrost is not on. I have a 60 degree heated garage so the truck is starting warm.
Old Feb 2, 2007 | 02:09 PM
Franklin2's Avatar
Franklin2
I would take the belt off and grab the pulley and see if it moves side to side any amount. The only thing I can think it could be is the o.d. of the bearing spinning in the alternator housing when it's cold.
96f150
1997 - 2003 F150
Mar 14, 2017 09:02 AM
cityjack
Mar 1, 2017 12:17 AM
Icefan71
1997 - 2003 F150
Jan 15, 2017 07:52 AM
Jagesage
Jun 29, 2015 11:18 PM
fordman882001
Apr 11, 2013 10:03 PM
