O-ring sizes
Old Feb 2, 2007 | 07:48 AM
Pocket's Avatar
Pocket
O-ring sizes
I'm going to swap out the turbo pedistal on my truck for a non-EBP unit, but I need the sizes of all the upper and lower o-rings. If I remember correctly I think there are 4 of them.
Thanks
Old Feb 2, 2007 | 07:58 AM
Uzumati's Avatar
Uzumati
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Feb 2, 2007 | 08:04 AM
guzzle92's Avatar
guzzle92
or get the whole kit:
http://members.***.net/kcmdieselperformance/gaskets.htm
Old Feb 2, 2007 | 08:12 AM
Pocket's Avatar
Pocket
Alan, those are the exact o-rings I need. I just need to know what size. I have a big bag of viton o-rings sitting in my garage right now, but I'm not sure if I have the correct sizes.
Old Feb 2, 2007 | 08:36 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Small- Turbo to pedistal O-ring .421 x .560
Large- Turbo to pedistal O-ring .769 x .908
Old Feb 2, 2007 | 08:59 AM
Pocket's Avatar
Pocket
Thanks! That should work.
Old Feb 2, 2007 | 10:34 AM
SpringerPop's Avatar
SpringerPop
Y'know, given the usury markup that both Ford and other vendors get for o-rings, we need to start an o-ring "registry" for those used in the 7.3's.
O-rings are measured by nominal "inside diameter" and "cross-section" or material thickness, thus the ones we use for the yellow fuel drain valve would be measured as 1/4" x 1/8". O-rings are also sized by the AS568A number. http://www.pspglobal.com/o-ring-sizes.html is a pretty good index on the web.
So, does anyone want to start a new thread specifically to collect sizing information about the rings used in the 7.3?
Pop
Old Feb 2, 2007 | 12:50 PM
Pocket's Avatar
Pocket
I think it would definately come in handy. I know I've lost/destroyed/mixed up o-rings in the past and finding a replacement can sometimes be a PITA.
Old Feb 2, 2007 | 05:44 PM
Uzumati's Avatar
Uzumati
If yall will PM me the Size and what its used for I will put a chart up on 7point3
Old Feb 2, 2007 | 05:58 PM
SpringerPop
How about a column or two for Grainger and McMaster-Carr part numbers, as well as the AS568A number, too? Maybe preferred material, too.
Pop
Old Feb 2, 2007 | 06:21 PM
Uzumati's Avatar
Uzumati
Use Type Size Vendor Part Number Package AS568A Number
Anything Else we need
Old Mar 2, 2007 | 05:08 PM
clintbonnie's Avatar
clintbonnie
Hey guys... I am replacing the two o rings in the fuel bowl shut valve and trying to insert the new o rings into the black housing and they don't seem to fit.. too large on the outside diameter by .028 using my digital calipers.. Are you suppose to force them in? They don't flex much, being that they are so hard.. What am I doing wrong? Using McMaster-Carr p/n 202 viton. The recess hole for the o ring measures .484 in diameter and the new o rings measure .512. (the old factory o ring measures .489 or .005 larger the recess hole)
Risk176
Mar 19, 2011 06:37 PM
BII Plow Truck
Bronco II
Dec 22, 2009 07:32 PM
Macamon
May 6, 2009 12:32 PM
katbird704
Sep 27, 2008 05:48 PM
Byron43
Jun 7, 2007 11:55 AM
