MLP Sensor
Old Feb 1, 2007 | 11:34 PM
Owl's Avatar
Owl
Unhappy MLP Sensor
My 92 clubwagon (302 with automatic overdrive) is making hard downshifts sometimes for no reason. It does it intermitently and not on the upshifts. Trans is smooth otherwise and no other problems. Trans was rebuilt 40,000 miles ago and has been good since.
From reading these foums I think it might be the MLP Sensor and I would like to change it out. My question is.. is this a hard job and what is involved?
Thank you all in advance.
Owl
Old Feb 2, 2007 | 07:39 AM
95bogginbronco's Avatar
95bogginbronco
The MLP is not hard to replace. It is easier to explain in steps.
1. Put truck in nuetral and block the tires.
2. Disconnect plug from MLP
3. Hold linkage with pair of pliers and break nut loose.
4. Take the 2 little bolts the align it loose.
5. Clean all the mud out from behind the sensor.
6. make sure the white or black tab on the new sensor is lined up with the other tab on it. This is nuetral on the switch and you need to install it in this position.
7. Put MLP on tranny and install linkage nut.
8. Install both nuts. Use a 1/4 inch ratchet. they don't have to be that tight.
9. Test drive and make sure every gear on your selector column works. If not loosen those 2 nuts with teh truck in nuetral, move it a little and try again. What this does is align the insides so they are correct without using that super expensive tool ford has for them.
Good luck buddy.
Old Feb 2, 2007 | 08:41 AM
Clubwagon's Avatar
Clubwagon
Well, my first thought is that your '92 doesn't have one. Most '92's with 5 liters have AOD's in them. This is a non-electronic transmission and therefore doesn't have an MLP.
The way to tell is if it has an OD On/Off button on the end of the shifter. If there is a button, its a 4R70W and indeed has an MLP. If there is no button then its an AOD and doesn't.
Steve
'95 Clubwagon XLT
Old Feb 2, 2007 | 09:18 AM
Owl's Avatar
Owl
Thanks for the help. Mine does not have a button on the shifter so I guess I don't have a MLP. What would I have then to change out for controling the trans? Would I have a modulator?
Owl
Old Feb 2, 2007 | 11:29 AM
Clubwagon's Avatar
Clubwagon
AOD's don't have a modulator, they have a TV (Throttle Valve) cable instead. Un-forced downshifts sound more like its falling out of gear. That's a line pressure problem. You need to have the problem professionally diagnosed. It may be the TV cable is too tight or the TV valve is hanging.
Steve
'95 Clubwagon XLT
Old Feb 4, 2007 | 08:53 PM
Owl's Avatar
Owl
Thanks for the help clubwagon. My downshifts are not un-forced. I should clarify, when I punch the accel. to pass, the trans will drop out of OD to the lower gear very hard. Also sometimes when I let go of accelerator and coast to a stop the trans will go into its lower gears with a clunk.
all forward gear shifts are smooth otherwise. Do you think the tv cable adjustment might be the source of my problems? It has been the same way now for about a month. And just recently the van is idling high and I think the IAC is dirty or in need of a replacement. Its been -22F here the last while so I haven't been able to look at it. (don't have a garage).
Any help very much apreciated.
Owl
Old Feb 4, 2007 | 09:22 PM
Clubwagon's Avatar
Clubwagon
If the problem is as you described, I doubt its the TV cable adjustment. That usually shows up on the upshifts first. Harsh downshifts, as you described, are usually an internal problem.
Steve
'95 Clubwagon XLT
Old Feb 6, 2007 | 01:34 AM
rick_369's Avatar
rick_369
Have you checked your Universal joints?
Johnny Bellardine
15
Sep 13, 2022 01:22 PM
mr1
Jun 9, 2016 08:48 AM
stockcar26
2004 - 2008 F150
Oct 14, 2015 02:27 PM
my91stealth
15
Dec 22, 2010 04:46 PM
bigolebluef150
Nov 20, 2006 03:09 PM
