1978 - 1996 Big Bronco
Coolant capacity
Old Jan 4, 2003 | 10:09 PM
treehugger36's Avatar
treehugger36
Coolant capacity
Alright. I know my owners manual would tell me but seeing as how the manual wasnt in the Bronco when I bought it I need to ask. I am refilling the radiator in my Bronco after just replacing my heater core. What I need to know is how much coolant/water mixture do i put in the radiator. and is there a special trick to it. Like I have been told to fill it up and run the bronco with the cap off the radiator and when the bronc gets to a normal driving temp top off the radiator. Is that correct. I know this sounds like a 5 year olds newbie question but I am trying to learn as I go.
Thanks
Peace
Treehugger36
"Full size man! Not one of those pansy Bronco II's!!!"
Old Jan 5, 2003 | 04:39 AM
greystreak92's Avatar
greystreak92
Coolant capacity
The method you described should work just fine. Make sure if there is a valve that shuts off the coolant flow to the heater core, that you have it open when you refill the system (for obvious reasons). I believe that some year Bronco's had these valves which were cable actuated in-line in the hose that feeds the heater core. Don't ask me which years though. I know my 92 does not have this valve. Once you have topped off the radiator, keep whatever you may have left over with you in the truck for a while and check the overflow resevoir periodically to make sure the system remains full after all the air bubbles have worked their way out. I have never had to add more than a half cup of coolant to top off at the end of a week after draining and filling the system. Its just a precaution on my part to carry the extra coolant around for a while in the event yours truly got stupid and missed tightening a hose clamp.
Old Jan 5, 2003 | 09:17 AM
fcarruth's Avatar
fcarruth
Coolant capacity
treehugger49
All Things Towing
18
Mar 14, 2015 08:39 AM
treehugger49
New Member Introductions
Feb 23, 2015 10:52 AM
Bronco_601
May 20, 2014 12:34 PM
Bronco_601
Aug 10, 2013 06:02 PM
ManfredVonRichtofen
28
Aug 9, 2013 12:27 PM
