Ignition
Old Feb 1, 2007 | 10:43 AM
bassproguy07's Avatar
bassproguy07
Ignition
Ok someone stuck a screwdriver in my ignition trying to start it and I cant get my key in there. I bought a replacement ignition but i cant get the other one out without having the key in there in the run position. Is there any other way to get it out besides drilling the whole lock cylinder out?
Old Feb 1, 2007 | 01:35 PM
bigblackF250's Avatar
bigblackF250
Probably not, looks like you may have to drill it out. I have replaced the one in my 93 and yes the key has to be in the run position and pushing it the little tab under the colomn.
But on that same note, if it is already screwed up why not go ahead and break in internally and then turn it to run, you can probably do this with a screw driver.
Old Feb 3, 2007 | 02:40 AM
Cool6.9DieselGuy's Avatar
Cool6.9DieselGuy
use a slide hammer some how, I guess you just screw in to the key hole and slam it down and the ignition will pop out, you can learn a lot from a professional car theif!
MattyJessome
16
Feb 6, 2021 11:27 AM
NewEnglander
1978 - 1996 Big Bronco
17
Apr 16, 2012 11:46 PM
5004man
13
Jan 28, 2008 02:09 PM
orangedbowl
May 10, 2005 11:09 PM
bowwow
Jun 1, 2002 08:32 PM
