Avm Hubs
Old Jan 31, 2007 | 06:46 PM
pinz's Avatar
pinz
Avm Hubs
Hello , This may be hashed over and over,but I bought the avms and do I have to disconnect anything but the old hubs to make these work on my 99 ranger 4.0 4x4. I have been reading the forum and I am not sure about the vacume line thing before I mount them on my truck all I have to do is turn the hubs to lock and just switch to high or low as needed ,please help me understand this.
Old Jan 31, 2007 | 07:42 PM
bcjim's Avatar
bcjim
I did not do anything other than take old off, put new on. Works. The vac is irrelavant once you install the hub locks as far as I know. The lugnut covers wont fit over them was the only drawback for me.
Old Jan 31, 2007 | 09:49 PM
wendell borror's Avatar
wendell borror
The dial in the truck will operate the electric shift motor on the back of the t-case to give you high and low range at the t-case. The new hubs will lock in your axles. Just lock in the hubs, get in your truck and move the dial to the desired range and take off.
Old Feb 1, 2007 | 08:03 AM
Rockledge's Avatar
Rockledge
When I install my AVM hubs, I'm going to disconnect the the PVH solenoid harness connector. I'm also going to plug the vacuum line between the solenoid and the reservoir tank. There will no longer be a need for the solenoid to energize, and I don't want any vacuum being diverted (or leaking over) to the PVH system.
Old Feb 1, 2007 | 06:36 PM
pinz's Avatar
pinz
I just wanted to thank all you guys for the info for my hub question THANKS this forum is awesome
Old Feb 1, 2007 | 07:27 PM
bcjim's Avatar
bcjim
I wondered about doing something like that, but didnt want to spend time trying to figure out what was what, and possibly screw something up. If you could take a picture while you are in there and post it, maybe I'll do likewise.
Old Feb 1, 2007 | 10:32 PM
Rockledge's Avatar
Rockledge
If you take off the passenger front wheel and remove the splash guard, you will see the vacuum reservoir tank in plain view. Just follow the vacuum line that connects it up with the PVH solenoid.
Old Feb 2, 2007 | 03:53 PM
bcjim's Avatar
bcjim
OK, When it warms up I'll have a look.
cmorningstar01
Mar 20, 2010 07:18 PM
YellowRanger2001
Feb 7, 2008 08:14 PM
tractortug
Feb 16, 2007 09:18 PM
blueranger99
15
May 20, 2006 08:39 PM
SPECOP
Mar 30, 2004 05:10 PM
