Battery cable question
Old Jan 31, 2007 | 06:34 PM
trike1946's Avatar
trike1946
Question Battery cable question
I need some long custom made battery cables. Any idea where I can order some or can I use welding cable? Thanks for any help.
Old Jan 31, 2007 | 07:27 PM
FARM69's Avatar
FARM69
I've taken my old ones to the parts house and they can cut you new ones on the spot.
Old Jan 31, 2007 | 09:20 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Also any tractor/farm implement company can make them up any lenght or size that you need.
Old Feb 2, 2007 | 02:36 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
welding cable works fine if you have it on hand
Old Feb 2, 2007 | 05:58 AM
trike1946's Avatar
trike1946
Thanks for the replies. Being in NJ, we don't have any tractor/farm supply around here. It seems like all we have is houses. I guess I will try the welding cable. Is it size for size or does the welding cable have to be larger? I am moving both batteries back near the rear of the truck. I need about 17' cables.
Old Feb 2, 2007 | 08:06 AM
fishmanndotcom's Avatar
fishmanndotcom
i bought 10 feet of 2 gauge battery cable for 1.88 a foot and then a couple of ends for $5 at advance auto
-cutts-
Old Feb 2, 2007 | 09:51 AM
ckal704's Avatar
ckal704
The farther away you move the batteries from the starter, the thicker the gauge cable you should use. I can't give you exact sizes, but I can tell you that if you try to pull a bunch of amps through a cable too thin, it will heat up. Might not burst into flames immediately, but over time, it will cause accellerated hardening of the insulation and subsequent problems.
handyandy123
Nov 9, 2017 12:10 AM
bkgeig
Dec 16, 2016 11:42 AM
hink10
Nov 11, 2012 09:47 PM
snaponprofile
May 7, 2011 08:43 PM
wpnaes
Dec 12, 2010 10:13 PM
