Move it or not?
Old Jan 31, 2007 | 05:31 PM
Hamberger's Avatar
Hamberger
Originally Posted by blake 7.3L
I have the stock down pipe and heat shields(they are neat). I do have a 3" body lift. Will this help?
The 3" body lift will help a lot. You should see how tight the factory installation is. I have a hard time believing that you could upgrade your downpipe from the factory 2 1/4 to 3" without a body lift. It is just too tight to the firewall.
Seb.....
Old Jan 31, 2007 | 07:57 PM
Winger235's Avatar
Winger235
When I refurbished my winter ride I stripped the truck to the frame. I installed neoprene body mounts and an additional inch lift. Mostly to be able spray water up and into the nooks and crannies. What a difference and inch made just to get the air cleaner off! I can't imagine changing over to a turbo setup on a stock cab mount. When they did the down pipe upgrade on the 95-97 PSD you had to cut the floor away to fit the pipe and the stock pipe was flat just to fit in the truck!
RodneyH
Jan 3, 2011 02:58 PM
mmaliga
Mar 30, 2010 02:55 PM
mackay86
Jul 12, 2009 06:10 PM
TooL
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Aug 21, 2006 08:27 AM
