Modular V10 (6.8l)
Under drive pulley
Old Jan 30, 2007 | 08:59 PM
lugnutt's Avatar
lugnutt
Under drive pulley
Does anyone make an underdrive pulley for the V10? I have an issue with my truck. Under heavy acceleration, when it shift gears. All the accerories on the engine keep spinning too fast, and the belt squeels until I let out of the throttle.
Ive upgraded the trans, so it shifts instantly and hard.
Any thoughts? New belt!
thanks lug
Old Jan 31, 2007 | 09:20 AM
FortyFords's Avatar
FortyFords
Get a new belt tensior and a new belt.
The springs in the tensior get weak
Also chk all pulleys for bad bearings.
Rich
Old Jan 31, 2007 | 09:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
And get a new belt with the toothed ribs - Dayco makes one, cured my (entirely stock) V10 from squeeling the belt at the 1-to-2 shift at 5000+RPMs
By the way, this was a known issue with 2000-2001 (if I recall correctly) V10's... Ford made an updated toothed belt, or something to that effect.
Old Jan 31, 2007 | 10:19 AM
Fredvon4's Avatar
Fredvon4
Aw come on now guys....
we can have 6 or 8 length wise RIBs but I have not see a gimler toothed belt on a Ford FEAD unless it was twisting a 6/71 roots!
FWIW... 6 rib belts will work ON 8 rib pulleys but the 8 rib belt is too wide for the 6 rib pulleys.....
There are still the correct width serpentine belts in the replacement parts system that have NO ribs... they squeal a LOT!
Old Jan 31, 2007 | 07:19 PM
TeamMudd's Avatar
TeamMudd
as for UNDERdrive pullies..........i know JET, EDELBROCK and a few other's make under drive pullies......when i was looking for them, i found that most brands revert you back to the 5.4 kit. i was "told" that all the pullies (crank, alt, pwr steering) from the 5.4 kit will fit the V10's as well! the kits came in both 6 & 8 groove i think
i never got around to ordering a kit due to the fact that ALL the kits i checked into stated that if you run larger than 36-37" tires (even with re-gearing) NOT to run an underdrive pully set...........so i can't say i know what they'll do, or how much you will gain, or notice from the kit................
but try you a good new name brand belt (like gates) and see how that works. i changed my 2000 rangers serp belt from the stock to a GATES brand belt after a mudding trip and never had anouther sceech out of it!
Old Feb 1, 2007 | 12:50 AM
MadMedic20's Avatar
MadMedic20
The stock power steering pump on the SD sucks anyways. I wouldnt want to slow it down and make the already stiff low speed steering any worse.
Old Feb 1, 2007 | 07:39 AM
mizzitch's Avatar
mizzitch
Agreed - I've stomped on the brakes (dropping the engine rpm real low) and tried to steer, let's just say I'm glad there was room to not make the turn.
Old Feb 1, 2007 | 10:17 AM
hydro_37's Avatar
hydro_37
Hang a snowplow on the front and then try to steer at idle. Especially in an apartment building parking lot between cars. Not any fun at all.
