I got my sheilded cable today.
Old Jan 30, 2007 | 08:45 PM
pullinair's Avatar
pullinair
Question I got my sheilded cable today.
How are you guys running your new shielded cable out of the pcm? I called Jody today and he said I could drill a small hole directly behind the chip and make a straight shot to the dash. or.... Run it like the ribbon cable was installed. Any insight?
Old Jan 30, 2007 | 08:47 PM
MAKO314's Avatar
MAKO314
I drilled the hole ,works great and the small wires look awful frail to be bending around to much
Old Jan 30, 2007 | 08:48 PM
TwelveAlpha's Avatar
TwelveAlpha
http://rides.webshots.com/photo/2190...00036958hUIbVU
notched the housing with a dremel
Old Jan 30, 2007 | 08:51 PM
pullinair's Avatar
pullinair
Sounds like drilling it is! Looks to be a tight fit now with the sheilded version.
Old Jan 30, 2007 | 08:55 PM
Uzumati's Avatar
Uzumati
I came out the back of the PCM housing then turned up to the dash, if you try to run it like the ribbon cable it gets pretty tight making that bend.
Old Jan 30, 2007 | 09:00 PM
pullinair's Avatar
pullinair
Thanks for the info. Was anyone having problems with the ribbon? I seem to be behind on the subject. Started spring semester at college and been real busy. Will I notice a diff? More questions I forgot to as Jody when i had him on the phone tonight.
Old Jan 30, 2007 | 09:09 PM
Uzumati's Avatar
Uzumati
Some people were gettin an intermitant cutout with the ribbon so Jody replaced everyones cable when they determined it was interferance related.
Old Jan 30, 2007 | 09:16 PM
pullinair's Avatar
pullinair
Ok I'll be swithing out as soon as it warms up above 32 degrees. .
