Modular V10 (6.8l)
Changing the spark plugs
Old Jan 30, 2007 | 12:52 PM
i eat hybrids's Avatar
i eat hybrids
I was thinking about changing the spark plugs. 98,000 on the original plugs from the factory. But im worried about the spark plug shooting out after tightening the new spark plug in. Its an 01 V-10. Do you think i have to worry about this? I heard about the earlyer v-10s, but didnt the 01 and up get the new heads to with more threads to stop this? Should i just let my local ford dealership mess with this? One last question, what type of sparkplugs to you guys recommend for the v10?
Old Jan 30, 2007 | 01:02 PM
Big Orn's Avatar
Big Orn
I could type alot of stuff for you - but it's much better if you do a search and print out what's already here about it. It will save alot of time for you and you'll get a quicker response and pics to boot!!!
Old Jan 30, 2007 | 03:02 PM
jutahh1's Avatar
jutahh1
autolite APP 103 gapped .54 torqued 160 inche pounds
https://www.ford-trucks.com/forums/4...th-photos.html
Old Jan 30, 2007 | 03:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
There's an official plug-change thread, just talked about in the past few days...
Ford supposedly went to long-thread heads late in calendar-year 2002.
I have seen pictures of the older '99 heads with very few threads.
When I did the plugs in my 2001, manufactured 10/2000, I could swear I have long-thread heads - I looked. But I'm not sure anymore.
Old Feb 1, 2007 | 09:20 PM
i eat hybrids
Thanks for all the help. I think i am going to have the dealership change them. I dont want to risk a blow out by torking it the wrong way.
Old Mar 12, 2007 | 11:56 AM
ed foster's Avatar
ed foster
Don't trust them
It sounds easy to just have the dealer change the plugs but what do you think they do when they run into a few that don't want to come out? Ship It!! I've seen more than a few Tritons that have OE plugs in the back holes and newer ones up front.
Old Mar 12, 2007 | 12:36 PM
Ricohman's Avatar
Ricohman
Hmmmmm.....
Its the V8 Monza spark plug change all over again!
Old Mar 12, 2007 | 01:16 PM
chuck641's Avatar
chuck641
It really isn't hard to change the plugs on the v-10. The back ones are a little hard to get to but not impossible. Get a torque wrench and you will be fine. Even without one as long as you don't over-tighten them you won't have a problem. Theres a chance of some moron working on your truck at the dealership and screwing it up or just not changing some of the plugs like was mentioned before. I vote do it yourself and use the motorcraft plugs.
Old Mar 12, 2007 | 01:18 PM
krewat's Avatar
krewat
I've got a beer gut, and it still wasn't all that hard. Lots of hard mats on top of the radiator and stuff, and it's easy to basically lay on top of everything with your feet on a step ladder or other reasonable footing. I've always thought of making something that bolts through the front tow hooks that you could stand on, but never got the gumption (yet).
Old Mar 12, 2007 | 04:41 PM
i eat hybrids
I havent done it yet. I was going to to it soon though mayb in a couple of weeks. If the dealership did it and lets say two days later the plugs spit out. Would they fix the heads?
Old Mar 12, 2007 | 04:57 PM
Big Orn's Avatar
Big Orn
I've heard horror stories after a plug blowout that the dealer installed.
I think I would get it in writing from them that they would be responsible for all plug failures including thread damage. This means COP, boots, plugs, connectors and wiring.
Do I think they will sign such a document? No.
Don't mean to come across so negative, but some techs will act ignorant because they are told to do so. Unless you personally know a tech at the dealer, I would have to change the plugs myself, following the FTE procedures to a TEE.
Old Mar 12, 2007 | 06:23 PM
Fredvon4's Avatar
Fredvon4
I helped change plugs for a bud some years back and one was real stubborn... eventually it break loose..
Guess what... the previous owner keep all the receipts and those plugs had been installed by a dealer... what is significant you might ask?
The stubborn plug was tight because it was held into the stripped threads of the head by JB Weld!
Old Mar 13, 2007 | 06:48 AM
Big Orn's Avatar
Big Orn
YIKES!!! Another horror story to add to the list!!!
What is sad (probably said this a thousand times already) is the fact that we know this design is poor; we know that with just a minor revision in the thread depth, this would have never been a problem.
My words of wisdom for today: A problem is only a seed from which sprouts a solution. Write that down....
Of course there will always be instances where someone cross-threads a plug, be it in cast iron or aluminum, but ignorance is bliss. All we can do here is encourage everybody to pay attention to detail. Stop, take a breath (or a brew) and realize that with just a little more patience and knowledge of the problem - we shall overcome.
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
CoachJoe
2009 - 2014 F150
Jan 8, 2013 05:11 AM
Courtney Williams
Jan 7, 2013 09:43 AM
305dgar
Modular V10 (6.8l)
15
Apr 23, 2012 03:09 AM
Bdox
18
Jan 20, 2008 10:29 AM
