Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Need Help, Lightning Questions!!
Old Feb 3, 2007 | 02:18 PM
zombie_46's Avatar
zombie_46
getting back to the original concern of it bogging down, it has happened a few times when i dont make the truck down shift to first but is in the boost and it will bogg down at 3800rpm and lose 300rpm so i dont really think it is totaly rpm related, but maybe load related, had 2 diffrent tunes from two diffrent companys and always did it with both after i put in the 2800 rpm stall and valve body!!! i am going to get a better
valve body any possibiliy that could be the problem?
thanks for the info
adam
oh my best was 1.7 60ft and 7.9 1/8th mile
Old Feb 3, 2007 | 11:42 PM
Blurry94's Avatar
Blurry94
Originally Posted by zombie_46
...had 2 diffrent tunes from two diffrent companys and always did it with both after i put in the 2800 rpm stall and valve body!!!
Were these mail order tunes?
It's hard to diagnose a problem without seeing some hard data. If you haven't had it on a dyno, then it would be a good idea to take it to one, espcially with the mods you have. Datalogging engine and transmission info to help get your rig dialed in properly.
Another thing i thought of is that your converter may be going from un-locked to locked at WOT.
hennecy
17
Nov 15, 2012 07:08 PM
Rockaholic
May 14, 2012 11:47 PM
beeturbo
Jun 16, 2009 10:38 AM
blkbrd36
41
Feb 8, 2008 07:42 PM
lightning guy
Oct 12, 2001 11:15 PM
