Modular V10 (6.8l)
Mercon vs. Mercon V
Old Jan 29, 2007 | 10:33 PM
jutahh1's Avatar
jutahh1
Mercon vs. Mercon V
Have a '99 F250 83,000 miles with the 4r100 tranny and just changed the fluid in the pan (didn't drain the converter) and added Mercon per manual spec. Well just out of curiosity I checked my repair invoice from 40,000 where the dealer flushed the tranny and added Mercon V ! Now I have half Mercon and half Mercon V in my tranny! What should I do ?
Old Jan 29, 2007 | 11:48 PM
Racerguy's Avatar
Racerguy
According to TSB 06-14-4..............
Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be serviced using MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V. After July 1, 2007, MERCON® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
Old Jan 30, 2007 | 09:00 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I wouldn't worry about the mix, jutahh1
Mercon V has some anti-chatter additives similar to what goes into limited-slip rear-ends.
I don't think the oil itself is any different in viscosity or anything else.
Dave raises a good point, Ford has phased out Mercon in favor of Mercon V. While this goes directly against the warnings they put in the owner's manual about "Mercon ONLY!", I don't think that warning is telling you to avoid Mercon V.
We've discussed this many many times. We've heard from people using Mercon V for a hundred-thousand miles and no issues.
Old Jan 30, 2007 | 12:55 PM
jutahh1's Avatar
jutahh1
Thanks 4 the reassurance krewat, I was getting a little worried there 4 a minute.
jutahh1
ps I also noticed that the dealer didn't change the tranny filter @ 40,000....should I go ahead and change it now @ 83,000 ?
Old Jan 30, 2007 | 04:54 PM
hydro_37's Avatar
hydro_37
Anytime I have the tranny pan off I am going to replace the filter. But I like to do whatever I can to prolong the life of my truck.
Old Jan 31, 2007 | 05:16 AM
davzog's Avatar
davzog
My wife's cousin is the service manager for a Lincoln dealer...he told me awhile ago that Mercon V was developed as a semi-synthetic ATF with additives to eliminate transmision shudder in the newer automatic trannys. He also said that the Mercon V can be used anywhere Mercon is originally recommended by the factory...they can be mixed without worry, unless the tranny starts to shudder.
I have topped off a transmission with Mercon V many times (it is all I ever buy), not knowing what was in the tranny to begin with...never had an issue.
Bottom line, you should be fine, but next time I would personally opt to use the Mercon V....
Old Jan 31, 2007 | 07:20 AM
krewat's Avatar
krewat
Absolutely correct! Mostly for the torque converter shudder.
The problem is, the 4R100 never HAD any shudder... so it never needed Mercon V.
Which is where the debate comes from. The 4R100 never needed Mercon V to eliminate TC lockup shudder.
But, it is spec'd to replace Mercon, so ...
Old Jan 31, 2007 | 03:38 PM
biz4two's Avatar
biz4two
Arrow
According to my 2003 SD V10 Service schedule the tranny filter should be changed per the following:
--> Change automatic transmission/transaxle fluid and filter @ 150,000miles
biz
Old Jan 31, 2007 | 06:00 PM
Antelope V-10's Avatar
Antelope V-10
Just a question, since MerconV has an anti shudder in it, would it be like putting too much friction modifier in the LS? IE the converter would slip on lock up and the clutch pack in the tranny slip?
Old Jan 31, 2007 | 08:21 PM
krewat's Avatar
krewat
That's exactly what I would think.
The Mercon V I put in my '96 t-bird 4.6L and the '97 Cougar 4.6L definitely made it shift better. Less "grabby" in slipping, but the clutches still 100% grabbed at the same time - it seemed.
BTW, BOTH at exactly 4 years to the MONTH since build-date, one had 50K miles, the other only 12K, had torque converter shudder. Funny how two vehicles with two totally different driving styles both did the TC shudder when they clicked over 4 years old. Some additive in regular Mercon go south after 4 years?
Anyway, having smelled Mercon and Mercon V, I can say that there is a hint of friction-modifier in it.
I didn't want this to turn into a Mercon vs. Mercon V thread again...
However, there is a marked difference in clutch "grabbiness"
Old Jan 31, 2007 | 08:43 PM
18vtx00's Avatar
18vtx00
after years of disputes for finnaly says that V now replaces III. that is all we use now.. good luck...just drain it and put in MV.
Firefighter 1406
Oct 20, 2016 02:50 PM
RedBirdin96
Oct 14, 2016 12:42 PM
Bullitt390
Feb 24, 2015 01:26 AM
BLK94F150
Oil & Lubrication
Feb 21, 2006 05:43 PM
Sport45
Jun 22, 2005 09:44 PM
