1978 - 1996 Big Bronco
Axle Help?!?
Old Jan 13, 2003 | 12:31 AM
grif95's Avatar
grif95
Axle Help?!?
I have a 1980 Bronco. I want to know where I need to go on the net to find some heavy duty part to beef my Dana 44RR TTB and rear 9" to handle a 429cj. I need to rework the front axle soon. Whoever had this rig before me didn't keep the u-joints in the front greased. Now there is a lot of slack there. If I am going to do it, I want it as heavy duty as possible. Please help?? Suggestions, personal experiences, and web sites needed... Also, does OxLocker make a set-up that will work on the front and rear?? I also want to go with the heavier splinded axles.
Old Jan 13, 2003 | 08:23 AM
honney's Avatar
honney
Axle Help?!?
An OX locker won't work with your front TTB because you need to use their special diff cover.
You'll destroy that front end in short order if you like the skinny pedal with that big block. There are no options to beef it up. Swap in a solid axle. A Dana 60 would be ideal but they're expensive and hard to find anymore. Even with a Dana 44 at least you could get the Warn shafts and CTM joints.
Old Jan 13, 2003 | 10:22 AM
90EBBronco's Avatar
90EBBronco
Axle Help?!?
tubolove
Ford Truck Parts for Sale
Nov 27, 2012 09:30 AM
GQROD
29
Feb 22, 2010 06:12 AM
Ford6.9
Sep 17, 2004 07:59 PM
weldingfreak
Jul 28, 2004 06:08 PM
46stude
Oct 12, 2003 09:41 PM
