C6 Shifter Seal
Old Jan 29, 2007 | 12:27 PM
slstreit's Avatar
slstreit
C6 Shifter Seal
When removing the valve body in a C6, (required for removal of the shifter shaft for seal replacement) what do I need to watch out for when removing & replacing the valve body so all works correctly at the end of the day?
Thanks for any input.
Old Jan 29, 2007 | 12:38 PM
monsterbaby's Avatar
monsterbaby
Lets get this into the tranny forum so you get better answers, hopefully faster too.
but what to watch for is don't lose the bolts, watch where they come from (2 different sizes and some are different lengths) and make sure that the shift linkages are engaged into the valves on the VB properly when you reasemble it.
Oh and in case you got them in some kit or another do NOT use gaskets between the VB and the case, it bolts up metal to metal, at most use an anorabic sealer if you feel the absolute need to use anything and don't be overly generous with that if you do.
reamer
Feb 19, 2017 09:43 PM
Don Vito
Nov 26, 2016 11:18 AM
Rusty_S
Oct 12, 2015 12:19 PM
charliea
Mar 4, 2011 07:01 AM
Bruce
Jul 11, 1999 09:29 PM
