Offroad & 4x4
need help 1345 bg transfer case
Old Jan 29, 2007 | 09:07 AM
clunker86's Avatar
clunker86
i just got my 1345 bg transfer case put on my truck after 2 years with out it. i never used this transfer case before so i dont know what it was like then. i have a 86 f250 400 c6 4x4. the problem is when i go to put it in 4 wheel drive 4l 4h its hard to shift into. i got it in 4l low and played a little and went to put it back into 2 wheel drive and i couldnt get the damn shifter to move.
i went under the truck tried to move it by hand, no luck. took the linkage off and tried to move it again and wouldnt budge. taped on it with a hammer still no luck. so i used a ratchet strap to put it back into 2h.
does anyone know what the problem maybe or how to fix this. and if the transfer case needs rebuilding how hard of a job is this. i am good at figgering things out. i took a diesel truck and put a gas motor and more stuff.
thank you
Old Jan 29, 2007 | 09:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
the transmission has to be in neutral to shift the transfer case between high and low gears, and should be in neutral to shift between 2 and 4 wheel.
it took me 2 weeks of head bashing before i read the owners manual to find this little ditty out.
Old Jan 29, 2007 | 09:42 AM
clunker86's Avatar
clunker86
what about park. after the first few times of trying to shift it i put it in pask and messed with a lot in park and in park with the truck shut off
Old Jan 29, 2007 | 09:44 AM
clunker86's Avatar
clunker86
im afraid to go back out there and mess with it again. i need to be able to drive it.
Old Jan 29, 2007 | 09:48 AM
tjc transport
i ain't rite
not sure on park, cause with the parking prawl in the trans, you will load the gears just like it is in gear.
in neutral, the only resistance there will be is that caused by the brake pedal. that is why when shifting to 4 wheel or 4 low you let off the brake and it goes in.
i never thought about it when i had the 5 speed in the truck. when i put the C6 and new t-case in, i freaked out for 2 weeks till i read the book, and then tried it and gave a little homer DOH!! when it slipped rite into gear and then back out.
Old Jan 29, 2007 | 09:54 AM
clunker86's Avatar
clunker86
ok i guess i need to give this a shot. i hope this fix the problem. i put too much money into the truck and im not read to put more in it now, lol. on that shifter how do you take the wobble out of it. i got the bolt tight and it still moves side to side a good bite. do you have any ideas on tighting that up. thank you
Old Jan 29, 2007 | 11:12 AM
tjc transport
i ain't rite
on your 1345, do you need side to side movement to shift??
the 1356 case i have in my truck requires you to move the shifter sideways to get it into neutral or 4 low.
you may also just have something stupid wrong with it like binding in the shifter. i have seen that many times. after a good cleaning and oiling the once frozen shifter works as smooth as a hot knife through butter again.
Old Jan 29, 2007 | 02:11 PM
rebocardo's Avatar
rebocardo
Turn off the vehicle, let it roll in N, while shifting out of 4LO or 4HI. It is the only way I can get mine out and the previous owner taped a big letter to the visor with the ENGINE OFF warning. I do believe it is a BW1345 too.
I never had to do this with any standard transmission vehicle, but, hey, it is pretty tough to get an standard in a V-8 van. :-)
Old Jan 29, 2007 | 03:34 PM
clunker86's Avatar
clunker86
ok i tried the n and then shift into 4 wheel. it went in and out 4h but couldnt get it to go in n or 4l. i know i got to replace the little rubber do hopper gor my linkage now. its all messed up from pulling the linkage of. does any one else have any ideas of what else. i also tried with my hand to shift it but would not budge.
Old Jan 29, 2007 | 03:46 PM
tjc transport
i ain't rite
are you sure it is a 1345?? it may shift like my 1356. to go into neutral or 4 low, you pull the shifter towards the driver side door while pulling back towards the seat.
Old Jan 29, 2007 | 03:51 PM
clunker86's Avatar
clunker86
it has 1345 bg stamped on the transfer case on the back side under the out put shaft.
Old Jan 29, 2007 | 03:59 PM
tjc transport
i ain't rite
actually, sorry, i posted that wrong. the shift pattern is not determined by the case, but by the shifter.
it is possible you have a 1356 shifter on a 1345 case.
from what i can gather, the difference between the two shifters is the 1345 pulls straight back, and the 1356 pulls back, over, then back again.
vtgboss
29
Oct 10, 2018 07:35 AM
Pete Roberts
21
Feb 1, 2014 10:27 AM
clunker86
Feb 27, 2007 06:35 PM
clunker86
Dec 23, 2006 04:39 PM
