turbo ?
Old Jan 28, 2007 | 11:10 PM
boostedv606's Avatar
boostedv606
turbo ?
Well for starters I have a 2006 ford f150 v6 4.2l. It will go into the shop next week to get boosted.parts are as listed
gt35r turbo
arospeed intercooler
snow performance meth/water injection
greedy bov
turbonetics wastegate
custom aluminum pipes and manifold
60lbs cobra injectors
dual cobra intank fuelpump setup
diablo sport tunning on the dyno
from what I am told and have read 8 psi is my limit on the stock motor?
well basically I wanted to know your opinions and suggestions.I have so many questions but I dont wann make this huge so just any information I can recieve would be nice the more detailed questions will follow.
By the way it is hard finding stuff for a 2006 f150v6
Old Jan 29, 2007 | 02:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Jan 30, 2007 | 11:59 AM
boostedv606
damn not one reply
Old Feb 1, 2007 | 02:10 PM
302s&460srocks's Avatar
302s&460srocks
you should be safe at 8 psi... you can probably run 15 psi with an intercooler without detonation but the stock pistons and rods won't like that much boost...
Old Feb 1, 2007 | 06:42 PM
boostedv606
I will be running an intercooler plus m/w injectionso I think im gonna dyno running 8psi and 10psi to see the difrence.If it worth the xtra 2 psi than ill leave it at 10psi
Old Feb 1, 2007 | 07:23 PM
FTE Herman's Avatar
FTE Herman
I busted a rod at 14 psi on a stock supercharged motor. I would not be afraid of 10psi.
Old Feb 3, 2007 | 09:06 PM
boostedv606
thanks for the feedback.......any other opinions on what equipment im running or any other upgrades i can do?
Old Feb 8, 2007 | 10:39 AM
95BroncoBeast's Avatar
95BroncoBeast
I'm not trying to shoot ya down, but I would've gotten a V8. You'd get bigger bang for your buck, IMO. Additionally, I'd be worried about head gaskets with the V6, if it is still the cam-in-block design. The earlier ones, IIRC were 3.8 blocks and I know the 3.8 had head gasket issues. I replaced a bunch of them.
Old Feb 8, 2007 | 04:00 PM
boostedv606
It would have been nice to have the v8 5.4l but i kinda wanna do things alitle diffrent.This is a demo vehichle for my company so i think with a turbo ill get more attention.
Old Feb 8, 2007 | 06:19 PM
95BroncoBeast
Okay. Sounds cool.
Old Feb 9, 2007 | 01:35 PM
pronstar's Avatar
pronstar
Your truck will be very fast with 8 - 10 psi on a turbo setup.
You should make great numbers while still remaining somewhat conservative, so it should still give you good reliability.
I'm not sure how strong the crank is on the 4.2, but it's relatively short since it's a V6 so it should hold up pretty well even if it's cast.
I'm curious about your 60-lb injectors. Seems a bit overkill for your setup, though they can likely be tuned to run well. Why 60 as opposed to a 42? Just curious, not slamming your setup or anything.
Old Feb 11, 2007 | 07:45 PM
boostedv606
the 60lbs injectors were chosen for future upgrades..eventually I will be building the block to handle more psi and I dont wanna have to buy the injectors twice
Old Feb 11, 2007 | 11:18 PM
RangerPilot's Avatar
RangerPilot
Very cool...not often you see a turboed V6 in a full-size pickup.
Actually...I've never seen one. Would love some pictures when you get around to it. Dyno results would be even better!
Old Feb 12, 2007 | 09:25 AM
boostedv606
as soon as I can get my truck out of the shop ill take some pics and post them but i have to learn how to do that
Old Feb 13, 2007 | 12:48 PM
boostedv606
I hate having to wait for my truck to be done.I wanna drive it allready
