turbo housing
Old Jan 28, 2007 | 03:27 PM
stang's Avatar
stang
turbo housing
would this turbo housing be worth it? and also, i know this is stupid, but how do i tell if my turbo is wastegated or not? its a 1997 psd. also do they make and up graded compressor wheel for the 94-97 psd? thanks. Ted
Old Jan 28, 2007 | 04:18 PM
andy's 96' 250's Avatar
andy's 96' 250
if your turbo is stock there is no wastegate
ltfox's Avatar
ltfox
Is the housing worth it.... YES, every penny.
Only 99+ powerstrokes were wastegated.
No their is no compressor wheel upgrade for the 94-97 psd. These trucks come stock with the wheel the superduty guy upgrade too.
Old Jan 28, 2007 | 08:30 PM
stang's Avatar
stang
thanks for the info, i guese that would be my next up grade heh!, what upgrades after that should i look at? intercooling is deffinetly on my list, where can i get that center pipe thing thats all one peice? you know, the casting or what ever it is, ill make the rest my self thanks!
Old Jan 28, 2007 | 08:36 PM
ltfox's Avatar
ltfox
Ya need to find one off a early 99 powerstroke. Or some have cut up the y-pipe and made into what ya need. I have used both housings, and if ya have no plans for injector ugrade in the near future, its well worth it!
Old Jan 28, 2007 | 11:10 PM
ForemanES's Avatar
ForemanES
Like ltfox said with stock injectors a smaller housing will help out, but larger injectors will spool the stock housing pretty quick. Also the smaller housing you get the more drive pressure is on the compresser wheel.
Old Jan 28, 2007 | 11:37 PM
stang's Avatar
stang
if i stayed with the smaller injectors what hps and tq gains would i see with this smaller housing, and if i went to larger injectors and stayed with the stock houseing what hp and tq gains would i see, and what is the cost of larger injectors and suppporting mods. thanks
Old Jan 28, 2007 | 11:50 PM
ForemanES's Avatar
ForemanES
With stock injectors (95cc) the max HP numbers you will see is 220-230 hp with good programming. The housing will just move the numbers to a lower rpm.
With larger injectors (stage 1s for example 160cc) and the stock housing hp numbers jump to 350+ with custom programming. Stages 1s set you back about $1,000 for rebuild ones. Supporting mods would be an intercooler if you tow so another $500-600. It all boils down to what you want and money.
Old Jan 29, 2007 | 09:49 PM
Reptar360's Avatar
Reptar360
There is an early 99 intake y-pipe listed on ebay right now. Item number 180079640607. It is listed as "7.3 powerstroke diesel innercooler wye connector" Hope this helps you....
Skyler Hewitt
Apr 5, 2016 08:04 PM
rollingthunder77
Apr 19, 2015 04:21 AM
Rrgeise
Sep 18, 2014 01:41 PM
Splatts
Dec 28, 2011 09:23 AM
ryanben
15
Jun 11, 2003 03:18 AM
