1978 - 1996 Big Bronco
Need a New Rear
Old Jan 4, 2003 | 12:28 AM
alpine7572's Avatar
alpine7572
Need a New Rear
Hey Guys,
Just came back from dealer -Friend of Mine works for Ford and found out that my rear is shot. The thing had a slow leak and when he checked the fluids, it was a quart short. So eventually the bearing started to wear and he said there was aot of metal shavings that were on the diff plug.
What is the price range I should pay for a used one. He said that I should go to a junk yard and pick one up. I looked online at and found that they range from $250-$600.
And is there any recommendations from anyone who lives in Jersy on where I can find one.
Thanks
Mike
Old Jan 4, 2003 | 01:58 AM
blownbronco's Avatar
blownbronco
Need a New Rear
I told you!;-)
Old Jan 4, 2003 | 08:57 AM
alpine7572's Avatar
alpine7572
Need a New Rear
Yeah Man. Friggin Sucks!
I have to call junk yards today to see what I can find.
Old Jan 4, 2003 | 09:09 AM
steve83's Avatar
steve83
Need a New Rear
If you could wait a few weeks, I'd sell you my '96 3.55 open for $450 (shipped), but my old 3.08 hasn't been rebuilt yet so I'm still driving on it. The last one I sold ('88 3.55 LS) went for $200. You shouldn't have trouble finding them in junkyards, but some may give you a price like $800, which is a rip-off. You can use any '87-96 FS pickup or Bronco rear axle, and you'll save a LOT of time & money if you buy it in the right ratio. I'd look for one that shows NO sign of ever having been opened (no silicone sticking out of the cover and the ID tag still attached), but that may be hard to find.
Old Jan 4, 2003 | 01:13 PM
alpine7572's Avatar
alpine7572
Need a New Rear
Hey Steve,
How many miles do you have on it?
is it a locking rear?
Thanks
Mike
Old Jan 4, 2003 | 01:34 PM
tite4x4's Avatar
tite4x4
Need a New Rear
hey alpine7572
Where are you located? I have an 8.8 from a 90 Bronco sitting in my back yard. Has the stock 3.55 gear ratio and open differential. Never been worked on and I did not have any problems with it. Going to a 9" rear might be a problem with not having the RABS in it. I'm sure there would be a way to put in a 9" rear in, and by passing the RABS system if you really wanted the 9".
They biggist problem with the 8.8" rearends is the c-clips. The open diff. with spider gears is another problem. I've heard alot of people put in limited slip or lockers in. I had my 8.8" rear end custom built. I had a limited slip, 4.10 gear ratio, put in, and I had the axle flanges that hold the drums in place cut off and the 9" axle flanges welded in place, then mounted rotors and calipers in place. The brackets for the calipers are what is holding the axles in place, eleminating the c-clips. I haven't had any problems with limited slip at all.
Hope this helps
Happy New Year to all
Old Jan 4, 2003 | 01:55 PM
alpine7572's Avatar
alpine7572
Need a New Rear
I Live in Edison NJ
Old Jan 5, 2003 | 12:02 AM
steve83's Avatar
steve83
Need a New Rear
The '96 had about 60Kmi when I bought it, and by the time I swap this axle out, I'll probably have put another 6Kmi on it. It's an open diff, as most Eddie Bauers had.
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=13181
Old Jan 16, 2003 | 04:31 AM
penguinasa's Avatar
penguinasa
Need a New Rear
i just replaced the 1/2 ton rear in an 88 bronco with a 3/4 ton HD for a f-350. it is a 10.25" and should take the pressure of the EFI 460. i paid 200 for it in AZ. hope this helps.
Old Jan 16, 2003 | 05:05 AM
galaxiefiveohoh's Avatar
galaxiefiveohoh
Need a New Rear
