1978 - 1996 Big Bronco
dana 60
Old Dec 5, 2002 | 05:12 PM
88bronco351's Avatar
88bronco351
dana 60
has anyone or heard of anyone putting a dana 60 in the rear of a bronco? would it be hard to do?
Old Dec 5, 2002 | 05:21 PM
bronco cam's Avatar
bronco cam
dana 60
[updated:LAST EDITED ON 05-Dec-02 AT 06:22 PM (EST)]There are companies you can buy dana 60s from custom built to fit the application you desire. They are set up to bolt on. You can set one up yourself. You might have to shorten it or move the spring pads. You also might check out a 14 bolt corporate rearend they also are bulletproof.
Old Jan 14, 2003 | 10:07 PM
steve83's Avatar
steve83
dana 60
Old Jan 16, 2003 | 03:52 AM
penguinasa's Avatar
penguinasa
dana 60
i just put a 10.25" rear end in my 88 bronco. it came out of a f 250 super duty. it bolted right up. the biggest problem is finding the u bolts and plates. i know this isn't a dana 60, but i am told that the 10.25" is strong enough for the EFI 460. hope this helps a little!
Old Jan 16, 2003 | 08:18 AM
honney's Avatar
honney
dana 60
The 10.25 is much stronger than the D60 rear.
To the original question, if you get one from a 77.5+ truck it'll bolt right up. You might need a new rear u-joint, and I'm not sure about parking brake cables. You'll lose your RABS sensor but for an '88 it's no big deal and RABS is useless anyway.
78BroncoMP
Oct 15, 2009 06:00 PM
88bronco351
Offroad & 4x4
Feb 2, 2006 02:38 PM
bronco460
Jun 28, 2005 08:52 PM
prodigy9904
Mar 23, 2004 09:57 PM
