Rear Sag
Old Jan 27, 2007 | 07:52 PM
3KIDDAD's Avatar
3KIDDAD
Rear Sag
Has anybody removed the rear spring hanger extension brackets to give the rear a little lift? I just installed a lift kit and my rear eand sags. I'm wondering if I can remove the extension brackets and bolt the springs directtly to frame mounts to achieve a little extra lift in the rear.
TIA
Old Jan 27, 2007 | 09:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Wouldn't that LOWER it?
Old Jan 27, 2007 | 09:40 PM
3KIDDAD's Avatar
3KIDDAD
How do I post a picture
So I drew a quick diagram... saved it as a jpg how do I post it as a picture here???
Old Jan 27, 2007 | 09:47 PM
3KIDDAD's Avatar
3KIDDAD
Diagram
Ok so here is a quick drawing...
Old Jan 27, 2007 | 10:08 PM
TwelveAlpha's Avatar
TwelveAlpha
Correct me if I'm wrong, but isnt that bracket a swivel that allows your springs and axle to move up and down? As the spring flexes, it would get slightly longer or shorter. Bolted at both ends would prevent the spring from flexing.
If your tail end is low, you might be happier with a short block in there or having the springs re-arched.
Old Jan 27, 2007 | 10:34 PM
3KIDDAD's Avatar
3KIDDAD
That does make sense...You're probably correct but if that's true why don't the fronts have one?
Old Jan 27, 2007 | 11:09 PM
i eat hybrids's Avatar
i eat hybrids
3KIDDAD, what kind of lift kit did you install? When i installed my lift kit it sagged in the rear two. I just took out the blocks that came with the kit and put in a 3 inch block.
Old Jan 27, 2007 | 11:29 PM
3KIDDAD's Avatar
3KIDDAD
My lift is ProComp... where did you purchase the blocks?
Old Jan 27, 2007 | 11:31 PM
3KIDDAD's Avatar
3KIDDAD
Seems like most lift kits are designed to lift the front higher than the rear... anybody know why?
Old Jan 28, 2007 | 12:43 AM
TwelveAlpha
I think the theory is everyone wants to level the ride. Stock, as you know, is nose down. I rather prefer it that way. My 4" lift is only a 4" front. The back has a 5" block, an extra spring, re-arched, and bags. More like a 6/4. You can do whatever you want.
You can get blocks virtually anywhere that sells suspension parts.
I know I'll be flogged mercilessly if I'm wrong (I dont remember a lot about the front shackles on my truck, and your X could, actually, be a little different) but I'm thinking one of those pivots too.
Old Jan 28, 2007 | 05:06 AM
housedad's Avatar
housedad
The front definately have a shackle. I was just fighting with the ones on my truck in the wee hours this morning.
Old Jan 28, 2007 | 01:05 PM
3KIDDAD's Avatar
3KIDDAD
Housedad is right. I crawled under this morning and they are there. I didn't remember seeing them before. So it looks light the shackle brackets are there for a reason and can't be removed. My original thought was that Ford used these brackets on the Excursion to make it lower than the Superduty and therefore might be able to be removed. Thanks all for your responses.
Old Feb 15, 2007 | 02:02 PM
Jeepincj7's Avatar
Jeepincj7
Because most lift companies sell you a Superduty lift. The Excursion needs a spring in the rear that is 2" taller than the front lift height. For instance, a Donahoe Racing lift will come with a 6" front spring and an 8" rear spring. You will sit level then:
Old Feb 15, 2007 | 05:23 PM
3KIDDAD's Avatar
3KIDDAD
Thanks for that information... that does make sense. Seems like I see many other lifted vehicles with rear sag too. So I need to be looking for 8" lift rear springs to make this thing sit level without blocks?
big meat
Bronco II
Apr 10, 2022 12:38 AM
hpcbmw
32
Sep 30, 2016 09:59 PM
jtfisher63
Nov 23, 2015 11:19 PM
minnesotafisherman
47
Oct 4, 2012 01:52 PM
GeneStoner
33
Jul 19, 2005 11:04 PM
