84 ford specs
Old Jan 27, 2007 | 02:55 PM
dumdum9599's Avatar
dumdum9599
84 ford specs
does anyone know where i can find the 84 f-150 spec
Old Jan 27, 2007 | 05:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
What specifications are you looking for?
Engine?
Transmission?
Rear End?
Front End?
Body?
They can change drastic from truck to truck, as well as model to model.
We would need some idea of what specs you are looking for.
Check your saftey certification lable and post all the codes from your truck, and that will give us a clue as where to begin.
Old Jan 27, 2007 | 08:25 PM
dumdum9599's Avatar
dumdum9599
i am looking for the engine specs it is a 351m
Old Jan 28, 2007 | 10:51 AM
81-F-150-Explorer
Well I have about 30 pages of Factory Engine specs for the 351M.
GENERAL SPECS:
Bore and Stroke: 4.00 x 3.50
Firing order: 13726548
Oil Pressure Hot @ 2000 RPM 50-75 psi
CILYINDER HEAD:
Combustion Chamber Volume: 76.9
valve guide bore diameter: .3433-
valve seat width: intake .060- / exaust
.070-
valve seat runout max: .002
valve arangement, front to rear RT: I-E-I-E-I-E-I-E / LT: I-E-I-E-I-E-I-E
Valve seat angle 45 Degrees
etc... etc...
Is there anything specific you want to know?
Old Jan 28, 2007 | 12:33 PM
82F100SWB's Avatar
82F100SWB
Hmm, 1984 should be a 351W. How many valve cover bolts on that unit? Six is a Windsor, 8 is a 335 series(351M/C/400)
Old Jan 29, 2007 | 06:05 PM
StillaKilla187's Avatar
StillaKilla187
I have an 83 with the 351M. Does anyone know the stock horsepower and torque specs?
Old Jan 29, 2007 | 09:24 PM
82F100SWB's Avatar
82F100SWB
An 83 should also be a 351W, it came in mid year 82, but, there may have been an carryover, Ford has been known to do odd things...
Best I can do for you is specs for an 81,
For the M, and the 300, the lower set of numbers is below 8500 GVWR, higher is above(F250HD/F350)
lewistg
Apr 14, 2014 11:11 AM
redman84
May 4, 2012 10:17 PM
TDbronco
Apr 23, 2002 09:39 AM
