Weak vacuum pump?
Old Jun 28, 2013 | 06:11 PM
jeem's Avatar
jeem
Weak vacuum pump?
Is it possible that the vacuum pump that runs my climate control and my esof could be getting weak? At first I had defrost only and my 4wd would not engage. I pulled the double line off of the solenoid and clamped the line coming from the pump. My climate control then worked so I figured that the vac lines going to my hubs were bad. They were very dry rotted so I changed them. Now my 4wd engages but sometimes it takes a while and the same with my climate control it will sometimes take a while before it will move off of defrost.
Old Jun 28, 2013 | 06:40 PM
BrandonT71's Avatar
BrandonT71
Do you have a Mighty Vac to test components and find possible leaks? How long does your vacuum pump run?
dallds
Feb 27, 2016 09:24 AM
mmenzies
Nov 7, 2012 12:02 AM
timf150
Nov 5, 2012 09:12 PM
fordhorse
Apr 1, 2011 10:43 PM
creich68
Oct 16, 2009 09:08 AM
