New Turbo
Old Jan 26, 2007 | 09:55 PM
JLG ANGUS's Avatar
JLG ANGUS
New Turbo
Well guys while hauling some hay last weekend, i blew the turbo hose off twice. Since i was loaded with 14 rolls i just put it back on as tight as i could. Wendesday dealer said they were replacing the turbo. My question? Is this turbo an improved one or same as what came on my 04 F250 FX4. Have not picked up truck yet will get it in the morning.
EAT MORE ANGUS!!!!!!
Old Jan 26, 2007 | 10:05 PM
jim6liter's Avatar
jim6liter
how many miles are on your 04 Angus?
Old Jan 26, 2007 | 10:19 PM
JLG ANGUS's Avatar
JLG ANGUS
My 04 has 38,000 miles at 15,000 i had a small oil leak on the motor but other than that no major problems
Old Jan 26, 2007 | 10:22 PM
jim6liter's Avatar
jim6liter
I wonder why they are replacing the turbo instead of the hose that blew off.There are updated hoses but I'm not sure of the turbo.
Old Jan 27, 2007 | 05:55 AM
npccpartsman's Avatar
npccpartsman
It's possible that the vanes are stuck in the turbo causing an overboost condition that's causing the hoses to blow off. They should probably clean the turbo first rather than replacing it or maybe they found some other problem causing it to overboost.
Old Jan 27, 2007 | 07:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
IMO it will be the same type.
Old Jan 27, 2007 | 08:19 AM
03f2506.0's Avatar
03f2506.0
On my early '03, I had 2 turbos replaced. 1st at 13K in '05 & 2nd at 15K miles in '06. Both turbos were part #3C3Z-6K682-AARM. About a month after the 2nd one was installed Ford came out with a new turbo upgarde with the # ending in BARM. Tech at dealer said my 2nd turbo had tapers on the ends of the vanes to prevent them from sticking. I was also told I should drive the truck more which I am and now have 21K on the truck and have not had any problems with the turbo, knock on wood. I am also using Stanadyne fuel additive since the 2nd failure. Don't know if the part# hold true for your '04 but hope this info helps.
Old Jan 27, 2007 | 10:23 AM
DEM 05's Avatar
DEM 05
Had my 1st turbo replaced at 29K on my 05 PSD X. The part # was 4c3z-6k682-cbrm. Cause was rust between VGT fins and housing. Set off engine code P0299.
The Trinity Kid
Aug 17, 2016 10:59 PM
angus1965
Dec 9, 2015 08:22 PM
j7angus
Mar 19, 2012 02:01 PM
angus21601
Oct 7, 2008 11:24 PM
angus
May 17, 2008 01:38 AM
