Carb spacer
Old Jan 26, 2007 | 02:07 PM
mswift's Avatar
mswift
Carb spacer
Guys.... I was curious to know of any advantages to having a carb spacer that has 4 holes in the center, or one large hole for all 4 butterflies?
Currently I have a 4 hole.
Thanks and Happy Firday!
Mike
Old Jan 26, 2007 | 02:47 PM
Bear 45/70's Avatar
Bear 45/70
The 4 holer helps low end torque and the single big on helps top end horsepower. And on a stock or near stock motor you will never notice the difference.
Old Jan 26, 2007 | 04:24 PM
mswift's Avatar
mswift
OK, thanks Bear. My motor is a near stock motor.
Also, what about spacer or no spacer? I just have always ran one, and have heard that it helps out with fuel burning process. Hence a smoother running engine. Bunch of horse schit blowing in the wind or what?
Mike
Old Jan 26, 2007 | 04:29 PM
Bear 45/70's Avatar
Bear 45/70
No spacer puts the carb right next to the manifold and that can transfer more heat to the carb. Carbs and heat are a no-no. I removed mine and installed a heat sync spacer set just because less heat is better. I prefer a space as long as I'm not running a manifold with very tall carb mount pad.
Old Jan 26, 2007 | 09:26 PM
baddad457's Avatar
baddad457
It's sometimes necessary to run a spacer to gain clearance for the carb linkage. Use the 4 hole.
zsir
Aug 20, 2005 11:02 PM
Alz Ryde
Jul 18, 2004 04:20 AM
cleanLX
23
Feb 12, 2004 07:48 PM
beartracks
Jan 24, 2002 12:31 PM
RobbieC
May 30, 2001 05:21 PM
