Did I isolate the problem? (randomly dies)
Old Feb 2, 2007 | 02:40 PM
Mil1ion's Avatar
Mil1ion
Well now that all the info is in the Other thread I don't know.
I've rquested that the threads be merged so everything is together the way it should be.
we can't be hopping from one thread to another to find out what's been done
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You cleaned out the tanks, when you removed the sending units did you check the filter screens? They sometimes fall off, too. Did you happen to shake the floats to see if you could hear gas sloshing around?
Are you sure there's no gas filter on the carb? Every 67/79 F100/350 had one originally. It screws in and somewhat resembles a 30-06 cartridge case, with the head towards the carb.
Old Feb 2, 2007 | 03:00 PM
dantennant_22's Avatar
dantennant_22
I haven't been in the tanks, and have not played with the sending units, filter screens, or floats. when I go the truck, there was a fram inline filter between the fuel pump and the carberator, when replacing hoses, I did not put that one back in, as advised by my step dad. I believe that my 3/8ths hose just fit over the carberator stem that pokes out ( if I remember right).
NumberDummy, do I need to look into cleaning out the tanks? do my symptoms resemble those of debri in the tank?
Mi1lion, sorry I don't believe I am bouncing around between posts. All the background information for the fuel system I meant to add to this post.
Hey, thank you!
Old Feb 2, 2007 | 06:39 PM
NumberDummy
Originally Posted by dantennant_22
I haven't been in the tanks, and have not played with the sending units, filter screens, or floats. when I go the truck, there was a fram inline filter between the fuel pump and the carberator, when replacing hoses, I did not put that one back in, as advised by my step dad. I believe that my 3/8ths hose just fit over the carberator stem that pokes out ( if I remember right). NumberDummy, do I need to look into cleaning out the tanks? do my symptoms resemble those of debri in the tank?
Hey, thank you!
Yes, Ford does have a nipple on the carb on some models, but if all you have is a nipple, then it was added when someone changed to the inline filter below. Just to be sure, check that nipple again. Dennis posted a good pic of a screw in fuel filter...take a look and see if it resembles what you have.
The tanks, even when the trucks are driven on a daily basis will collect scale and impurities, and gas today is full of impurities. Gaining access to underbody fuel tanks is a itchbay, so before going there, check the carb for a filter.
You may have to clean out those tanks one day.
Old Feb 2, 2007 | 07:54 PM
Mil1ion's Avatar
Mil1ion
No you aren't but for us to understand the whole thing WE would have to bounce back and for between threads.
That's why users are asked to "Go find their thread themselves" and post to it with further info or an update rather than start another one.
Now that everything is on one thread we don't have to.
My point is : Just keep posting to the original thread if what you are asking about it relates to it ..... not start others .
kdaug5
May 7, 2014 07:05 PM
Boss_358
Apr 11, 2009 08:34 AM
I8URCAT1
Nov 14, 2008 12:17 PM
HateTank
32
Jul 10, 2007 04:14 PM
dino360
Mar 28, 2005 10:10 PM
