uppipe replacement
Old Jan 25, 2007 | 09:37 PM
powerstrokr01's Avatar
powerstrokr01
uppipe replacement
my dealer wants 650 for parts and labor. does this sound right?
Old Jan 25, 2007 | 09:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If his labor rate is above $100 per hour it does.
Old Jan 25, 2007 | 09:44 PM
powerstrokr01
they say 5 hrs labor and the parts are around 200.00
Old Jan 25, 2007 | 09:55 PM
cookie88's Avatar
cookie88
FTE Emeritus
I see. Well, you can get all the parts yourself HERE for $110.
5 hours is probably the book time, but if takes a professional mechanic that long real time I'd suggest he needs to choose a different career.
Unless you are considering doing it yourself, which is difficult but very doable, it's not all that far out of line....but more than I would want t pay to fix a simple exhaust leak.
Old Jan 25, 2007 | 11:02 PM
jtharvey's Avatar
jtharvey
What all is involved with replacing the up-pipes? I did take a look under there when my trans was out (while at BTS) and it looks like there would be pretty easy access with the trans dropped. However, that's not feasable for a lot of people, me included.
Pulling the turbo is not a problem. But, after that it looks like there's not a lot of room to work.
Old Jan 25, 2007 | 11:30 PM
CSIPSD's Avatar
CSIPSD
Its not bad with the turbo out and the down pipe out... Maybe a afternoon for a first timer... Get all the parts not just the up pipes... DI has some nice SS one piece pipes... no dounuts to go out...
Old Jan 25, 2007 | 11:32 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Im doing manifolds and up-pipes on our 95 powerstroke. I'm dropping the ZF5 at the same time to replace the broken DMF and replace the clutch so it shouldn't be TOO hard to do.. Transmission out of the way would make it ideal. Why, do your's leak?
Old Jan 25, 2007 | 11:37 PM
jtharvey's Avatar
jtharvey
Yeah, there's a small leak that is no doubt getting bigger. The up-pipes also had some pretty good wobble to them when I had the turbo out a few weeks ago. I'm sure some replacement donuts would fix it, but I don't know that the clamps will be reuseable. They're pretty rusted.
Old Jan 25, 2007 | 11:50 PM
PowerstrokeJunkie
quick question- are there donuts at the lower connection at the manifold? All i discovered was donuts at the top..
Old Jan 25, 2007 | 11:56 PM
John311t's Avatar
John311t
No, there are no donuts at the lower connections.
Old Jan 26, 2007 | 04:23 AM
jetdoc's Avatar
jetdoc
Those DI units are 500 bucks...
Old Jan 26, 2007 | 06:59 AM
dmueller71's Avatar
dmueller71
I thought there was some kind of crush gasket at the bottom. Are those 2 bolts at the lower union easily replacable? That's my only leak, but it's noticable in the cold mornings when I get a little smoke from under the truck.
Old Jan 26, 2007 | 07:39 AM
jetdoc's Avatar
jetdoc
On cold mornings I get diesel fumes in the cab. Those up pipes are just a poor design. I cant answer your question, I havent had mine apart yet.
Old Jan 26, 2007 | 08:40 AM
jtharvey's Avatar
jtharvey
That's the other thing...like jetdoc, I'm starting to smell diesel in the cab during cold mornings.
Old Jan 26, 2007 | 09:15 AM
John311t's Avatar
John311t
You can try sprayin them down with some rust breaker. They will probably just break off. If they do not break off, they could just get stuck in the manifold, 2 of mine were rusted into the manifold, i had to take a air hammer to get them out.
