high beam problem
Old Jan 25, 2007 | 08:42 PM
RIsuperduty89's Avatar
RIsuperduty89
high beam problem
Whenever I go to turn the highbeams on they dont go on. Is there a switch that needs to be replaced? All the other lights work.
Old Jan 25, 2007 | 09:03 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I'd check the fuses first... if that's not the problem i'd suspect the multifunction switch.
What year do you have?
Old Jan 26, 2007 | 08:23 AM
RIsuperduty89
1997 4.0L ranger
Old Jan 26, 2007 | 09:43 AM
87ford4x4inline6's Avatar
87ford4x4inline6
Most likely it is the hi/low switch on the steering column. It is a combo turn signal and hi/low that will need replaced. Just replaced one on a 96 explorer doing the same thing.
Old Jan 26, 2007 | 10:05 AM
RIsuperduty89
thought so, thanks
john112deere's Avatar
john112deere
That switch is certainly a good possibility, but having changed one in a '97 Ranger a few weeks ago, I'd say it's a heck of a lot easier and cheaper to check the fuse first...
Old Jan 26, 2007 | 10:33 AM
87 XLT's Avatar
87 XLT
If you take a quick look at a wiring diagram you will see that the only difference between high beams & flash to pass is in the dimmer/multifunction switch.
So if the high beams dont work, but the flash to pass does work the dimmer/multifunction switch is shot.
Simple as that.
Old Jan 26, 2007 | 01:06 PM
wtroger's Avatar
wtroger
Iam not sure about a 97 but my 2003 has a 10 amp fuse that is for the high beams if it is blown or not there then you don't have high beams.
Old Jan 27, 2007 | 11:43 AM
RIsuperduty89
is the ten amp fuse in the regular fuse panel or the one under the hood.
Old Jan 27, 2007 | 10:20 PM
wtroger's Avatar
wtroger
The one inside the cab next to the drivers door
effie_man
Nov 26, 2007 11:12 PM
mustange70
Canadian National Chapter
13
May 19, 2006 01:21 PM
Jen
Georgia Chapter
Nov 22, 2002 09:41 AM
Hottarod
Feb 27, 2002 11:43 AM
