Offroad & 4x4
52" springs
Old Jan 25, 2007 | 02:22 AM
pwrstrokin19's Avatar
pwrstrokin19
52" springs
I have seen people reference to using the chevy 52" springs before on here but can seem to find those posts or any information using google. My question is did these springs give you lift also besides better flex and did you have to relocate the hangers and shackles? Reason i ask is i need some new springs for the 71 f250 which give me lift and more flex cuz these ones on there currently are way to stiff. So people that have done this swap would like to hear what you have done to get these to work? thanks
Old Jan 25, 2007 | 03:31 PM
75F350's Avatar
75F350
I use a 63" spring for the rear of my truck. They did come from a bow-tie, that I found in a junk yard. I did have to re-locate the hangers, and I did a shackle flip at the same time.
I first located the donor truck, and removed the springs, and the front hanger from the frame (chebbie). Then I removed both the front, and rear hangers from My 75' Ford. I used the original front hanger at the rear of the truck, and attatched the shackle. It now faces down, instead of up. (tension vs. compression) I then centered the new springs into the wheel well, and found the mounting locations for the front hanger, that came from the donor truck. The chebbie hanger is longer, and sits lower than the orginal one. This is important to compensate for the drop in the mounting location for the rear shackle. It just so happenad that I was able to use one of the original rear hanger mounting holes for the front hole in the new hanger. This ensured that the axle would stay square. After a few new holes were drilled in the frame, and new grade 8 hardware was installed. I was able to run a big tire with great flex,and a very good ride quality. The spring pack that you choose, will determine ride, and weight capacity, etc, etc. I went with a 1/2 ton spring. Was done in about 1 day, and a few beers.
For the front, I had Deaver spring arch a set that are 59" long, with an offset pin to keep the axle in the middle of the wheelwell. It required a new shackle be mounted at the frame,as it is now about 6" further back under the cab, but that too was easy, but not as cheap as the rear.
robert_l_ross
Sep 1, 2023 03:17 PM
FILTHY
28
Jul 26, 2016 08:08 PM
Jarryd
Jan 14, 2016 04:24 PM
GreatNorthWoods
21
Jan 4, 2016 01:16 PM
onebadv2
Jul 1, 2013 10:37 PM
