float level adjustment advice sought.
Old Jan 24, 2007 | 06:11 PM
killerkjn's Avatar
killerkjn
I put a carb kit in my f100 with a 223 engine and autolite carb. The directions in the rebuild kit says to set float at 1 3/32 inches. But my shop manual says to set it at 1 1/64 inches +or- 1/64. which do you think I should use. I run my truck close to sea level with outside air temps between 30 and 80 degrees. Also my main jet is a number 67 which show for 0-5000 ft applications. thanks much
Old Jan 24, 2007 | 08:08 PM
mountainrich's Avatar
mountainrich
If you're comfortable with readjusting the float- use the book setting. Most rebuilds are set too high.
If you have any transitional problems (from idle to main system) raise the float 1/16 or so at a time.
Thbifeb
Nov 15, 2013 07:12 AM
77camperspecial8
Jan 3, 2010 07:23 PM
paulbunyan22041
May 24, 2004 06:25 AM
paulbunyan22041
Mar 8, 2004 09:02 AM
bill ballinger
May 30, 2001 03:12 AM
