Hi guys,
Does anyone have any tips as to how to correctly set the float level in an Autolite 4300? This is my 2nd rebuild, my first one had the same problem. I have gas coming out of the bowl vents. The car runs fine, excellent even, but gas is spurting out of the top of the bowl vent tubes. I am guessing I have the float level seet incorrectly or maybe the float is hanging up on something when I install it back into the body.
At any rate...whats the easiest way to adjust the float? I got the measurements for my app and it says Primary should be 1/16" and the auxillary should be 49/64" . I have set those correctly but I still got gas flying out of the top of my carb. Anyone have any suggestions? I am in dire need of help. If someone is i n Arlington, VA or close by I will pay to have someone get my float adjusted right. I have to move my car shortly and I really am not tyring to buy a whole new carb just because I cant get the float adjusted right
if the measurements are correct , i would think something else would be the problem , those measurements are hard to get wrong. have you checked the needle and seat , iv had them fall out and not realize it untill i saw them in the bottom of the bowl,or is the float itself not all the way on the rod ? bob
Thanks for your reply! I had someone else recommend that I buy a new float. Ill try that and if that doesnt work I guess Ill wind up buying a whole new carb. Does anyone in the DC area have any carbs for sell or is willing to setr my float?? I can bring it to you and im willing to pay to get the float adjusted right...
I checked the needle and seat, threyre fine. No dirt or anything out of the ordinary there. I am going to order a new float today. If that doesnt get it I see AutoZone has new 4300s for $150. Ill probably buy one of those. Is there anyone on here in the DC area trying to sell an old 4300??
paulbunyan
