jumping a battery dead?
Old Jan 24, 2007 | 08:23 AM
star's Avatar
star
Jumping a dead battery on a 7.3,it has two batteries ,which one do I jump ? If in need of a new one ,do I replace both ?
Old Jan 24, 2007 | 08:41 AM
Pocket's Avatar
Pocket
You can jump either one.
Also replace both when you are ready to swap batteries.
Old Jan 24, 2007 | 08:44 AM
Smokin''s Avatar
Smokin'
Smokin
Keep in mind that jumpstarting a diesel can be extremely difficult, sometimes impossible. The one time I had mine jumped, we had to jump it with an F250 with dual batteries, and two sets of jumper cables.
Your two batteries are connected, so either one can take in the voltage needed to start the truck. You need to replace both because if one is weak, so is the other...and the weak battery you dont replace will drag your new one down the toilet.
Old Jan 24, 2007 | 09:06 AM
PA_Ford_Man's Avatar
PA_Ford_Man
Hopefully, the batteries died because an auxilliary device (headlights, radios, etc) was left on overnight and not because of internal shorts within the battery.
Something to consider is the vast amount of current needed to "Start" these PSDs. So, when you get a "jump" from a friendly motorist, it would be best to allow the charging vehicle to "charge" the dead batteries, prior to attempting a start.
Additionally, the typical "jumper cable" wire gauge is relatively small, compared to our battery cables. It is not capable of passing the current needed to actually "start" our trucks. With dead batteries, you might get a decent "arc" when making the last connection, created by an inrush to fill the depleted/shorted batteries. As always, make the last connection (-) to an engine mounted frame/bracket rather than a battery. Don't want "sparks" around a battery!
Just my thoughts, I'm not an expert
Old Jan 24, 2007 | 09:30 AM
star's Avatar
star
Thanks for all the info !
Old Jan 24, 2007 | 12:49 PM
Vijay's Avatar
Vijay
Can jump either and replace both if you have to...
courtneylaw
Jan 14, 2015 11:30 AM
lindasue
Aug 29, 2014 09:06 AM
MOOOOOPS
Sep 16, 2009 10:04 PM
tpolley
May 15, 2009 01:01 AM
jonny_blue
Electrical Systems/Wiring
Sep 26, 2005 08:56 PM
