302 info please d90e
Old Jan 23, 2007 | 05:15 PM
robertbourque's Avatar
robertbourque
igot numbers off the block maby some one can tell a specfic year. hp tq rating heads. heres the # d90e-6013-e3a then in small stamping 8j26 .then 37. and 79 with a circle around it. thanks
Old Jan 23, 2007 | 08:53 PM
Conanski's Avatar
Conanski
Te very first line on this page has a listing for casting number decoding....
In any event those heads are '79 vintage... which was right in the thick of the smog era. They have hugh chambers(69cc) which didn't build much compression and as a result the engine these came from probably had the lowest specific power output of any modern V8 at a measly 145hp or so...
Old Jan 23, 2007 | 08:59 PM
robertbourque
i guess im going to have to pull the heads and get numbers
Old Jan 23, 2007 | 09:05 PM
robertbourque
so what can i do to id the heads without pulling them off .also whats the 79 vintage heads as far as sparkplug size 3/8 ths .thanks bro
Old Jan 24, 2007 | 06:56 AM
ken75ranger's Avatar
ken75ranger
You can take off the intake and use a mirror to look under the edge of the head for a casting number.
Old Jan 24, 2007 | 10:06 AM
robertbourque
in 79 what hed would the use
Old Jan 24, 2007 | 06:03 PM
baddad457's Avatar
baddad457
In 79, about the only heads you'll see on a 302 are the D8OE boat anchors.
Old Jan 24, 2007 | 06:27 PM
robertbourque
soo they suck huh so what if i put e7s on it will it bring the hp up some oh and theres no smog hole in the exzaust ports what things do i look for to id D8OE heads??
Old Jan 24, 2007 | 07:21 PM
baddad457's Avatar
baddad457
D8OE on the bottom side of one intake runner. Pedestal rockers too as are all 78-up small block heads.
Old Jan 24, 2007 | 07:22 PM
baddad457's Avatar
baddad457
E7's would raise the comp ratio by about a half point or more, I don't have a calculator handy. Higher comp ratio = more hp.
Old Jan 24, 2007 | 07:23 PM
robertbourque
so if they have pressed in stud mount ther boat ancors and are trash?
pbeamtn
Jul 26, 2017 12:27 PM
jason90f150
Apr 4, 2017 05:13 PM
swoosh1958
Jan 4, 2017 06:19 PM
NoFrod
Large Truck
Oct 12, 2016 03:58 PM
Gen 1 driver
1978 - 1996 Big Bronco
Oct 24, 2015 08:52 AM
